1. Accessing Pabbly Chatflow to Start Automation
To begin automating your WhatsApp conversations, you first need to access Pabbly Chatflow. Open your browser and type in the URL www.pabbly.com/chatflow. Once there, you can either sign in if you’re an existing user or create a new account to get started.
After signing in, you will be directed to the Pabbly Chatflow dashboard where you can manage your WhatsApp integrations. To make the most of your experience, remember that new users get 100 free credits monthly. This is a great way to test out the features of Pabbly Chatflow before committing to a paid plan.
2. Creating Your AI Agent in Pabbly Chatflow
Once you’re logged into Pabbly Chatflow, the next step is to create your AI agent. Navigate to the AI assistant section on the left-hand side and click on “Add AI Assistant”. Here, you will name your AI agent, for example, “Astrology Chatbot”.
- Name your AI assistant (e.g., Astrology Chatbot).
- Select the instruction type as “AI agent”.
- Configure settings like temperature and API key.
This will set up the foundation for your WhatsApp AI agent. Make sure to save your settings to ensure your AI assistant is ready for use.
3. Configuring Your AI Agent’s Settings
After creating your AI agent, you will need to configure its settings within Pabbly Chatflow. This includes setting the temperature for responses, which determines the creativity of the AI’s replies. A lower temperature gives more focused answers, while a higher temperature allows for more creative responses.
Additionally, enter your OpenAI API key to connect your AI agent to the OpenAI model. You can find this key by visiting the OpenAI API keys page. Once you have entered the API key, save your configuration to ensure that your AI agent is connected properly.
4. Uploading Knowledge Source for Your AI Agent
To enhance your AI agent’s performance, you need to upload a knowledge base. This involves preparing a detailed document that includes all relevant information about your services. Use Google Docs to create this document, then download it as a PDF and upload it to Pabbly Chatflow.
- Create a comprehensive document detailing your services.
- Download the document in PDF format.
- Upload the PDF to Pabbly Chatflow as your knowledge base.
This knowledge base allows your AI agent to provide accurate and helpful responses based on user queries, making it an essential part of your setup in Pabbly Chatflow.
5. Enabling Your AI Assistant for WhatsApp Conversations
The final step is to enable your AI assistant for WhatsApp conversations. In Pabbly Chatflow, navigate to the inbox settings and select your newly created AI assistant. You can assign this AI assistant to specific chats or groups, streamlining your response process.
Make sure to save your settings after assigning the AI assistant to ensure that it is active and ready to handle incoming messages on WhatsApp. This allows your AI agent to respond to customer inquiries automatically, enhancing your business’s efficiency.
In this tutorial, we have explored how to automate WhatsApp conversations using Pabbly Chatflow. By following these steps, you can create an AI agent that efficiently handles customer queries, improving your business’s responsiveness.
