To start using Pabbly Chatflow for your WhatsApp marketing, open your web browser and go to pav.com/chatflow. This will take you to the homepage of Pabbly Chatflow, where you can either sign up for a free account or log in if you’re an existing user.
If you’re new to Pabbly, click on the “Sign Up for Free” button. Existing users can simply log in. For those looking to purchase a subscription, use the discount code “Rom Invite” at checkout to get a special offer. This code is also available on the left side of the video for reference.
2. Setting Up Your WhatsApp Broadcast in Pabbly Chatflow
Once logged in, navigate to the Pabbly apps window and click on “Access Now” under Pabbly Chatflow. This directs you to the dashboard where you can manage your WhatsApp communications effectively. Before proceeding, ensure you’ve connected your WhatsApp number to your account, as this is essential for sending messages.
  • Click on the “Broadcast” feature in the left sidebar.
  • Create a message template that you will use for your broadcast.
  • Ensure that your message template is approved by Meta.
After creating your message template, you can start setting up your WhatsApp broadcast. Click on the “Add Broadcast” button to begin the process. This is where you will define the broadcast name and select your contact list.
3. Importing Contacts into Pabbly Chatflow
To send your WhatsApp broadcast, you first need to import your contacts into Pabbly Chatflow. If your contact details are stored in a Google Sheet, download them as a CSV file. You can then upload this CSV file directly into Pabbly Chatflow.
To do this, go to the “Contacts” section in the left sidebar, and click on the “Add Contact” button. Choose the “Add Bulk Contacts” option to upload your CSV file. Once uploaded, your contacts will be added to your Pabbly Chatflow account.
  • Select the contact list to which you want to send your broadcast.
  • Use the refine audience option to exclude any contacts as needed.
After successfully importing your contacts, you can proceed to select your desired contact list for the WhatsApp broadcast.
4. Creating Your WhatsApp Broadcast Message
To create your WhatsApp broadcast, go back to the broadcast section in Pabbly Chatflow. Here, you will need to select the type of broadcast as “Broadcast Camp” and give it a name, such as “50% Off”. You will also choose your contact list from the ones you imported earlier.
Next, you will select the message type. You can either choose a pre-approved template or a regular message. Since you have already created a template, select it from the dropdown. You can also upload any media files you want to include in the message.
  • Test your broadcast by sending a test message to your own WhatsApp number.
  • Schedule your broadcast for a future date or send it immediately.
Once everything is set up, click on the “Add Broadcast” button to finalize your broadcast setup. You can view the stats for sent, delivered, and read messages once the broadcast is sent.
5. Conclusion: Effective WhatsApp Marketing with Pabbly Chatflow
In this tutorial, we explored how to use Pabbly Chatflow to set up a WhatsApp broadcast effectively. By following the steps outlined, you can easily inform your customers about promotions and updates in a single click. Pabbly Chatflow streamlines the entire process, making WhatsApp marketing accessible and efficient.
Now you can leverage Pabbly Chatflow to enhance your marketing strategies and reach your audience effectively. Start using it today to see the benefits firsthand!
