To automate WhatsApp customer queries, start by accessing Pabbly Connect. This platform is essential for integrating various applications seamlessly.
Open your browser and navigate to Pabbly Connect. After signing in, you can create a new workflow that will connect Pabbly, Pabbly Chat Flow, and OpenAI.
2. Setting Up Pabbly Chat Flow
Next, configure Pabbly Chat Flow to respond to customer queries on WhatsApp. This step is crucial for creating your AI assistant.
In your Pabbly Chat Flow dashboard, ensure your WhatsApp number is linked. Follow these steps:
- Navigate to the AI Assistant option on the left menu.
- Select the AI agent type you want to create.
- Configure the AI settings like temperature and choose OpenAI as your AI provider.
By following these steps, you ensure that your AI assistant is set up correctly to handle customer queries.
3. Integrating OpenAI API
The next step involves integrating the OpenAI API with Pabbly Connect. This integration is key for enabling AI-driven responses.
To do this, you will need your OpenAI API key. Here’s how to obtain and integrate it:
- Visit the OpenAI API keys page.
- Create a new secret key and copy it.
- Paste the API key into your Pabbly Chat Flow setup.
This integration allows your AI assistant to fetch responses from OpenAI, enhancing customer interactions on WhatsApp.
4. Configuring AI Assistant Settings
Now that the integration is complete, it’s time to configure your AI assistant settings in Pabbly Chat Flow. This step is vital for customizing responses.
In the settings, you can adjust various parameters, such as:
- Setting the AI temperature for creativity.
- Adding a header or footer message.
- Defining stop words that will halt the assistant.
These configurations ensure that your AI assistant responds appropriately to customer queries, providing a tailored experience.
5. Finalizing and Embedding Your Assistant
Finally, to complete the process, you need to finalize and embed your AI assistant created with Pabbly Connect into your website.
After saving your configurations, you can generate the embed code for your assistant. Here’s how:
- Click on the embed button in Pabbly Chat Flow.
- Copy the provided embed code.
- Paste this code into your website’s HTML.
Once embedded, your AI assistant will be live and ready to automate WhatsApp customer queries effectively.
In this tutorial, we explored how to automate WhatsApp customer queries using Pabbly Connect, Pabbly Chat Flow, and OpenAI. With these tools, you can enhance customer interaction and streamline responses effectively.
