To create a WhatsApp chatbot, first access Pabbly Chatflow by visiting www.pabbly.com/chatflow. If you’re a new user, sign up for free to receive credits that allow you to test the features.
After signing up or logging in, you will see the dashboard. Here, you can manage your WhatsApp number by clicking on the “Add WhatsApp Number” button. This step is crucial as it connects your WhatsApp account to Pabbly Chatflow.
2. Creating Your AI Assistant in Pabbly Chatflow
Next, you will create your AI assistant in Pabbly Chatflow. Click on the “AI Assistant” option on the left sidebar and then select “Create New Assistant.” Name your assistant, for example, “Automate WhatsApp Conversations in Minutes.” This will be the chatbot that interacts with your users.
  • Select the instruction type as “AI Agent”.
  • Set the temperature for AI responses (0 for focused, 1 for creative).
  • Choose OpenAI as the AI to use.
After setting these options, you will need to enter your API key from OpenAI. This key connects your assistant to the AI model. Ensure you save your settings to avoid losing your progress.
3. Configuring AI Assistant Settings in Pabbly Chatflow
Once your AI assistant is created, it’s time to configure its settings in Pabbly Chatflow. You can customize header and footer messages, set stop keywords for user queries, and define retry attempts for unanswered questions.
For optimal performance, you should also upload a knowledge base document. This document contains all the necessary information that your AI assistant will use to respond to user queries effectively. Make sure to format this document correctly to ensure the AI understands it well.
4. Assigning Your AI Assistant to Contacts in Pabbly Chatflow
After configuring your AI assistant, you can assign it to specific contacts or groups in Pabbly Chatflow. Navigate to the “Inbox” section and select the contacts you want to assign the assistant to. This ensures that all messages from these contacts will be handled by your AI assistant.
  • Enable AI auto-replies in the settings.
  • Select the assistant you created for this purpose.
  • Save your settings to apply the changes.
This step is essential for ensuring that your AI assistant is effectively integrated with your WhatsApp contacts, allowing for automated responses without manual intervention.
5. Testing Your WhatsApp Chatbot with Pabbly Chatflow
Finally, you should test your WhatsApp chatbot to ensure it works as intended. Send a message to your WhatsApp number and observe how the Pabbly Chatflow AI assistant responds. This will give you insights into the effectiveness of your setup.
If the responses are satisfactory, you can further refine your AI assistant’s knowledge base or settings based on user interactions. This iterative process will help improve the chatbot’s performance over time.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Chatflow. By following these steps, you can automate your conversations and enhance user engagement effectively.
