To start using Pabbly Connect for WhatsApp integration, visit the Pabbly Chartflow homepage by searching ‘pabbly.com/chartflow’ in your browser. This platform allows you to send bulk WhatsApp messages efficiently.
Once on the homepage, you’ll see options to either sign in or sign up. If you’re new, click on ‘Sign Up Free’ to create an account. Existing users can simply sign in to access their dashboards.
2. Setting Up Your WhatsApp in Pabbly Connect
After signing in, navigate to the Pabbly Chartflow dashboard. Here, you can connect your WhatsApp number by clicking on the ‘Add’ button. Pabbly Connect offers two methods for this setup.
  • Choose the method that suits your needs.
  • Follow the on-screen instructions to complete the connection.
Once your WhatsApp number is connected, you can access various features offered by Pabbly Connect. This integration allows for seamless communication and broadcasting of messages.
3. Creating a Message Template for WhatsApp Broadcast
Before sending bulk messages, you need to create a message template in Pabbly Chartflow. Navigate to the ‘Template’ section and review existing templates or click ‘Add Template’ to create a new one.
When creating a new template, you can either create it manually or generate it using AI. Make sure to submit the template for approval to Meta. Approved templates can then be used for sending automated messages.
4. Broadcasting Messages Using Pabbly Connect
To initiate a broadcast, go to the ‘Broadcast’ section and click ‘Add.’ Choose the type of broadcast campaign, and name it accordingly. For instance, you might name it “New Launch”.
  • Select the contact list from your Pabbly Connect account.
  • Choose the pre-approved template message for personalization.
Once your contacts are selected and the message type is set, you can proceed to send or schedule your broadcast. This feature is essential for businesses looking to communicate effectively with their customers.
5. Testing and Scheduling Your Broadcast
Before sending the broadcast, Pabbly Connect allows you to test your message. Enter your contact details and click ‘Send Test Message’ to ensure everything displays correctly.
If the test is successful, you can choose to send the broadcast immediately or schedule it for later. Make sure to select a future date and time if scheduling.
Once the broadcast is complete, you can view the stats for sent, delivered, and read messages. Pabbly Connect makes it easy to manage your communication and refine your approach based on the data collected.
Using Pabbly Connect for WhatsApp integration allows businesses to send personalized bulk messages efficiently. This step-by-step guide helps you leverage Pabbly Connect to enhance your communication strategies effectively.
