1. Accessing Pabbly Connect for WhatsApp Broadcasts
To automate WhatsApp broadcast messages, you first need to access Pabbly Connect. Start by visiting paby.com/chartflow in your browser. This will direct you to the Pabbly Chartflow homepage.
If you’re new to Pabbly, click on “Sign Up for Free” to create an account. Existing users can simply sign in. Once logged in, navigate to the “All Pabbly Apps” window and click on “Access Now” for Pabbly Chartflow. This is where the automation begins!
2. Setting Up Your WhatsApp Broadcast in Pabbly Connect
Now that you’ve accessed Pabbly Connect, it’s time to set up your WhatsApp broadcast. Locate the broadcast feature on the right side of the dashboard. Click on it to begin creating your broadcast.
  • Select “Add Broadcast” to start a new campaign.
  • Choose “Broadcast Campaign” as the type.
  • Name your campaign, for example, “Healthcare Plus”.
Following this, select your audience. You can either use an existing contact list or upload a CSV file. If using Google Sheets, download your data as a CSV and upload it to Pabbly Connect. For now, I’ll use an existing contact list.
3. Creating a Message Template in Pabbly Connect
Creating a message template is essential for sending WhatsApp broadcasts through Pabbly Connect. Navigate to the template section to see your existing templates. You can choose from approved templates or create a new one based on your requirements.
Once you have your template ready, ensure it includes any necessary media files. To send a WhatsApp message, your template must be approved by Meta. If you want to learn more about creating templates, check out the tutorials available on Pabbly’s YouTube channel.
4. Testing and Scheduling Your WhatsApp Broadcast
With your template set, it’s time to test your broadcast message using Pabbly Connect. Before sending it to all your contacts, send a test message to your own WhatsApp number. Input your contact details and click on “Send Test Message”.
Once you receive the test message, you can schedule your broadcast. Choose whether to send the message immediately or schedule it for a later date. If scheduling, ensure you select a future date and time. You can also enable automatic retries for any failed messages.
5. Viewing Broadcast Stats in Pabbly Connect
After sending your WhatsApp broadcast through Pabbly Connect, you can view its performance statistics. This includes the total number of messages sent, delivered, read, and any that failed. This data helps you understand the effectiveness of your broadcast.
Additionally, you can resend messages to any contacts that failed to receive them. This feature ensures that your important messages reach your audience without any hassle.
In conclusion, using Pabbly Connect to automate WhatsApp broadcast messages simplifies your communication process. By following the steps outlined in this tutorial, you can efficiently reach your audience with minimal effort.
