1. Getting Started with Pabbly Chatflow
To automate WhatsApp broadcast campaigns, the first step is to access Pabbly Chatflow. This platform allows you to integrate various applications seamlessly. If you are not a user yet, visit pabbly.com/chatflow and create a free account to start exploring its features.
Once you have signed up, you will receive 100 free credits each month. This is perfect for testing out the functionalities of Pabbly Chatflow. After logging in, you will land on the Pabbly Chatflow dashboard, where you can access all the necessary tools for your broadcast campaigns.
2. Creating a Broadcast Campaign in Pabbly Chatflow
To set up a broadcast campaign, navigate to the broadcast feature within Pabbly Chatflow. Click on the “Add Broadcast” button, which will take you to the campaign creation page. Here, you will need to select the type of broadcast you want to create.
- Choose “Broadcast Campaign” as the type.
- Name your broadcast, e.g., “New Shoe Arrivals”.
- Select your audience by choosing an existing contact list or uploading a CSV file.
For this example, you can upload a CSV file containing your contacts. Ensure that your CSV file includes columns for first name, last name, and phone number. This will help you reach up to 200,000 contacts with a single click using Pabbly Chatflow.
3. Selecting a Template for Your Message in Pabbly Chatflow
After setting up your audience, the next step is to define the message type. Within Pabbly Chatflow, you can choose between a pre-approved template message and a regular message. For this campaign, we’ll use a pre-approved template.
Click on the option to select a WhatsApp template and choose the one that fits your campaign. In this case, select the “New Arrivals” template for shoes. You can also add an image to make your message more appealing, enhancing customer engagement.
4. Testing and Scheduling Your Broadcast in Pabbly Chatflow
Once your template is ready, it’s crucial to test the broadcast before sending it out. Enter a test contact name and your phone number in the designated fields. Click on the “Send Test Message” button to ensure everything looks good.
After confirming the message, you can proceed to schedule the broadcast. Decide whether to send it immediately or at a later date. If you choose to schedule, select the date and time for the broadcast to be sent out, ensuring optimal timing for your audience.
5. Finalizing Your Broadcast in Pabbly Chatflow
Before finalizing, enable automatic retries for any contacts that might not receive the message initially. This feature in Pabbly Chatflow ensures that your messages are delivered without needing manual intervention.
Click the “Add Broadcast” button to complete the setup. Your campaign is now ready, and you can monitor its performance directly from the dashboard. Pabbly Chatflow provides detailed analytics to help you understand the effectiveness of your messages.
In conclusion, automating WhatsApp broadcast campaigns using Pabbly Chatflow allows you to reach a larger audience quickly and efficiently. By following the steps outlined in this tutorial, you can create engaging campaigns that enhance customer interaction and drive sales.
