To start automating your social media posting, you first need to access Pabbly Connect. Open a new tab in your browser and type pably.com/connect. This will take you to the Pabbly Connect landing page.
If you are a new user, click on the ‘Sign Up for Free’ button. Pabbly Connect offers 100 free tasks every month for automation. Existing users should click on the ‘Sign In’ button to access their accounts.
Once logged into Pabbly Connect, you will see the dashboard. Here, you can create a new workflow. Click on the ‘Access Now’ button to go to the Pabbly Connect dashboard.
  • Choose the Quick Workflow Builder option.
  • Type a relevant name for your workflow, like “Schedule Posts with Google AI and Facebook”.
  • Click on the ‘Enter’ button to create the workflow.
Your workflow is now set up to schedule posts daily. You will generate content using Google AI and post it to your Facebook page automatically.
3. Scheduling the Workflow in Pabbly Connect
To automate the posting process, you need to schedule your workflow in Pabbly Connect. Set the time for when you want the workflow to run daily. For example, you can choose to run it at 10:00 AM every day.
After setting the time, proceed to connect Google AI to generate the content. Click on ‘Add New Connection’ and follow the prompts to enter your API key from Google AI Studio.
  • Go to Google AI Studio and click on ‘Get API Key’.
  • Generate a new API key and copy it.
  • Paste the API key in Pabbly Connect and save your connection.
This setup allows your workflow to generate content automatically using Google AI at the scheduled time.
4. Posting Generated Content to Facebook
Once your content is generated, you need to connect your Facebook account to Pabbly Connect. Click on ‘Add New Connection’ again and select ‘Connect with Facebook Pages’.
After connecting, choose the specific Facebook page where you want to post the content. You will map the content generated by Google AI to the message box for posting.
  • Select your Facebook page, for example, “Digital Dynamics”.
  • Use the mapping feature to insert the generated content directly into the message box.
  • Click ‘Save and Send Test Request’ to finalize your setup.
After saving, your Facebook page will receive the generated content automatically at the scheduled time.
5. Conclusion
By following these steps, you can effectively automate your social media posting using Pabbly Connect, Google AI, and Facebook. This integration streamlines your workflow and saves time, allowing you to focus on other aspects of your business.
Utilizing Pabbly Connect for automation not only enhances efficiency but also ensures consistent engagement on your social media platforms.
