1. Accessing Pabbly Connect to Start Integration
To begin the integration process, you first need to access Pabbly Connect. Open your web browser and navigate to pabbly.com/connect. Here, you will find options to sign up or log in. If you are new, click on “Sign Up for Free” to create an account and get 100 free tasks monthly.
Once logged in, select “Pabbly Connect” from the dashboard. This is where you will create your workflow to connect Google Sheets with Google Blogger. After selecting Pabbly Connect, you can easily create a new workflow by clicking on the “Create Workflow” button.
In this step, you will set up a workflow using the Quick Builder in Pabbly Connect. Automation involves two main principles: triggers and actions. The trigger initiates the workflow when a specific event occurs, while the action is the response to that trigger.
  • Select “Google Sheets” as the app and set the event to “New Row”.
  • Copy the generated webhook URL provided by Pabbly Connect.
  • Add a new detail in your Google Sheet that will act as the trigger.
After setting up the trigger, you will need to install the Pabbly Connect Webhooks add-on in your Google Sheets. This will allow Google Sheets to communicate with Pabbly Connect, facilitating the automation process.
3. Setting Up Google Sheets for Pabbly Connect
Now, you need to connect Google Sheets with Pabbly Connect. Start by opening your Google Sheets and navigating to Extensions > Add-ons > Get add-ons. Search for “Pabbly Connect Webhooks” and install it.
After installation, refresh your Google Sheets. Click on Extensions > Pabbly Connect Webhooks > Initial Setup. Here, paste the webhook URL you copied earlier. For the trigger column, select the final data column (e.g., column H) where new data will be added.
  • Set the trigger column to the column where data will be populated.
  • Click on “Submit” to configure the setup.
  • Test the connection by sending a test data request from Google Sheets.
Once these steps are completed, you will see a confirmation that the connection has been set up successfully between Google Sheets and Pabbly Connect.
4. Integrating AI Tools with Pabbly Connect
Next, you will integrate your AI tool (such as Google AI) with Pabbly Connect. This involves obtaining an API key from your AI tool’s dashboard. Click on the provided link in Pabbly Connect to access your AI studio account.
Once logged in, create a new API key if necessary and copy it. Back in Pabbly Connect, paste the API key into the relevant field. Then, map the data from the Google Sheets trigger to the AI tool’s input fields.
  • Select the AI model you wish to use (e.g., Gemini 2.5).
  • Set the method to “Generate Content”.
  • Click on “Save and Send Request” to generate the blog content.
After successfully generating the content, you can now proceed to post it on Google Blogger using Pabbly Connect.
5. Posting Generated Content to Google Blogger
Finally, you will post the generated content to your Google Blogger account through Pabbly Connect. Click on “Sign in with Google” to authenticate your Blogger account and grant necessary permissions.
Once connected, select your blog ID from the dropdown menu and map the title and content fields from the previous steps. Set the status of the post to “Live” and ensure draft options are set as desired.
  • Click on “Save and Send Test Request” to finalize the post.
  • Check your Google Blogger account to confirm the new post has been created successfully.
With these steps, you have successfully automated the entire process of posting recipes from Google Sheets to Google Blogger using Pabbly Connect.
In this tutorial, we demonstrated how to automate the posting of blog articles on Google Blogger using Pabbly Connect and Google Sheets. This integration streamlines your workflow, allowing you to focus on content creation.
