To automate product and order queries on WhatsApp, start by accessing Pabbly Connect. This platform serves as the foundation for integrating various applications, enhancing your customer service capabilities.
Begin by creating an account on Pabbly Connect. After logging in, navigate to the dashboard where you can initiate the integration process. This involves connecting your WhatsApp account and setting up the necessary triggers and actions.
2. Creating Your AI Assistant with Pabbly Chat Flow
Next, use Pabbly Chat Flow to create an AI assistant that responds to customer inquiries. Go to the Pabbly Chat Flow dashboard and ensure your WhatsApp number is linked. This is crucial for enabling automated responses.
  • Select the AI Assistant option from the left sidebar.
  • Choose the type of assistant you want to create.
  • Configure the AI settings, including the temperature for responses.
These steps ensure that your AI assistant is tailored to handle specific queries related to your products and orders efficiently. Once set up, you can test the assistant’s functionality to ensure it meets your requirements.
3. Integrating OpenAI API with Pabbly Connect
To enhance the responses of your AI assistant, integrate the OpenAI API through Pabbly Connect. This integration allows your assistant to access a vast knowledge base, improving its ability to answer customer questions.
First, obtain your API key from OpenAI. Once you have the key, return to Pabbly Connect and navigate to the settings of your AI assistant. Input the API key in the designated field to establish the connection.
  • Access the OpenAI API keys page to generate your key.
  • Paste the API key into your assistant’s settings in Pabbly Connect.
  • Save the changes to finalize the integration.
This integration is crucial for ensuring that your AI assistant can provide accurate and relevant answers to customer inquiries based on the data it retrieves from your knowledge base.
4. Setting Up Your Knowledge Base for AI Responses
Your AI assistant’s effectiveness largely depends on the knowledge base it accesses. Using Pabbly Connect, you can upload a comprehensive knowledge base file that contains all necessary product information.
Upload your knowledge base in formats like .txt or .pdf directly through the Pabbly Chat Flow interface. This file will serve as the reference material for your AI assistant when responding to customer queries.
Ensure your knowledge base is well-structured and updated regularly to reflect current product offerings. This will help your assistant provide the most accurate information to customers.
5. Testing and Launching Your AI Assistant
After setting up your AI assistant and knowledge base, it’s time to test its functionality through Pabbly Connect. Initiate a test conversation to see how well the assistant responds to various queries.
Make any necessary adjustments based on the test results. Once satisfied with the performance, activate your assistant by switching on the toggle in the settings. This will enable it to start handling customer queries on WhatsApp seamlessly.
Finally, embed the assistant into your website if needed, using the provided integration code from Pabbly Connect. This allows customers to access the assistant directly from your site.
By utilizing Pabbly Connect, you can effectively automate product and order queries on WhatsApp with AI. This not only improves customer service efficiency but also enhances user experience significantly.
