1. Accessing Pabbly Connect for Your WhatsApp Chatbot
To create a WhatsApp chatbot for your business, start by accessing Pabbly Connect. Simply visit www.pabbly.com/chatflow in your browser. Sign in to your account or create a new one to get started.
If you are a new user, click on “Sign up for free” to receive credits that allow you to test the features. Existing users should click “Sign in”. Once logged in, you will see all Pabbly applications, including Pabbly Chatflow, which is essential for building your chatbot.
2. Setting Up Your WhatsApp Chatbot with Pabbly Connect
After accessing Pabbly Connect, navigate to the Pabbly Chatflow dashboard. Here, you will find options to add your WhatsApp number. Click on “Add WhatsApp Number” and choose the preferred connection method.
- Select “WhatsApp Connect” for a straightforward setup.
- Alternatively, use a manual token if you prefer that method.
Once your WhatsApp number is added, you can start creating your AI assistant. This is where Pabbly Connect shines, allowing you to automate responses for customer queries efficiently.
3. Creating Your AI Assistant in Pabbly Connect
To create an AI assistant, click on the “AI Assistant” option on the left-hand side. Next, click on “Add AI Assistant”. Name your assistant something relevant, like “Automate Photography Gear Rentals via WhatsApp”.
In the next step, you will set the AI instructions. Choose the instruction type as “AI Agent”. This is crucial as it defines how your assistant will respond to queries. The configuration allows you to set creativity levels; for example, a temperature setting of 0.7 offers a balance between creativity and focus.
- Select OpenAI as the AI to use, and choose the model, such as GPT-5 Mini.
- Ensure your API key is added correctly to connect with OpenAI.
With Pabbly Connect, you can easily manage these settings and ensure your AI assistant is ready to handle customer interactions effectively.
4. Configuring AI Assistant Settings in Pabbly Connect
Once your AI assistant is created, you can configure various settings. This includes setting a header and footer message, which helps in branding and providing essential information to users. Toggle on the options for these messages to display them during interactions.
Additionally, you can set a fallback message for instances when the AI cannot answer a query. This can be something like, “I am here to assist with questions related to company information or support.” This ensures that users always receive a response, even if it’s not the exact answer they were looking for.
- Adjust the retry attempts for unresolved queries, ranging from 1 to 10.
- You can also upload a knowledge base to help the AI provide accurate information.
Utilizing Pabbly Connect for these configurations allows for a seamless customer experience and ensures that your assistant is well-equipped to handle various inquiries.
5. Assigning Your AI Assistant in Pabbly Connect
After configuring your AI assistant, the next step is to assign it to specific contacts or groups. Navigate to the inbox settings in Pabbly Connect and enable AI auto replies.
You can select a list of contacts or apply the assistant to all contacts. This feature is particularly useful for businesses with a large customer base, as it automates responses without manual intervention.
Simply save the rules after selecting the AI assistant for the desired contacts, and your WhatsApp chatbot is ready to go! This automation through Pabbly Connect saves time and enhances customer engagement.
Creating a WhatsApp chatbot for your business using Pabbly Connect is a straightforward process. By following these steps, you can automate customer interactions, enhancing efficiency and user satisfaction. Leverage the power of automation today!
