To automate leads from Meta to GoHighLevel, start by accessing Pabbly Connect. Visit pabbly.com/connect and log in to your account. If you don’t have an account, you can create one for free, which includes 100 tasks per month.
Once logged in, you will be presented with the dashboard. From here, you can create a new workflow that integrates Meta lead ads with GoHighLevel. This setup does not require any coding skills, making it accessible for everyone.
2. Setting Up the Integration Between Meta and GoHighLevel
In your Pabbly Connect dashboard, click on “Create New Workflow”. Name your workflow and select the trigger app as “Facebook Lead Ads”. This step is crucial as it will capture leads generated from your Meta ads.
  • Choose “New Lead” as the trigger event.
  • Select your Facebook page and lead form from the dropdown.
After setting up the trigger, test it by creating a lead in your Meta lead form. This will allow Pabbly Connect to capture the lead details and prepare for the next steps.
3. Capturing Lead Details in Pabbly Connect
Once a lead is generated, Pabbly Connect will automatically capture the details. You can see the captured information in the workflow setup. This includes the lead’s name, email, phone number, and company details.
  • Verify that the lead details appear correctly in Pabbly Connect.
  • If everything looks good, proceed to set up the action step.
This step ensures that every new lead from Meta is captured and ready for integration with GoHighLevel.
4. Sending Leads to GoHighLevel
Now that you have captured the lead details, it’s time to send them to GoHighLevel using Pabbly Connect. Add a new action step in your workflow and select “Lead Connector V2” as the application.
Choose the action event as “Create or Update Contact”. This allows Pabbly Connect to either create a new contact or update an existing one in your GoHighLevel account.
Connect your GoHighLevel account by providing the necessary permissions. This step is vital to ensure that Pabbly Connect can interact with your GoHighLevel account seamlessly.
After connecting to GoHighLevel, map the fields from the captured lead data to the corresponding fields in GoHighLevel. This includes the first name, last name, email, and phone number.
Once mapping is complete, click on “Save and Send Test Request”. This will send a test contact to GoHighLevel. You can then check your GoHighLevel account to confirm that the lead has been added successfully.
With Pabbly Connect, every new lead from Meta will now automatically create a contact in your GoHighLevel account, streamlining your lead management process.
This tutorial showed how to automate leads from Meta to GoHighLevel using Pabbly Connect. By following these steps, you can easily manage leads without coding. Enjoy seamless integration and efficient lead management!
