1. Accessing Pabbly Connect for Your Integration
To start integrating Meta Ads with Salesforce CRM, you first need to access Pabbly Connect. Open your browser and navigate to pabbly.com/connect. This platform allows you to automate various business tasks without any coding skills.
Once on the Pabbly Connect website, you have two options: sign in if you’re an existing user or sign up for free if you’re new. Pabbly Connect offers a free trial, enabling you to experiment with automation features before committing to a subscription.
2. Setting Up the Trigger with Facebook Lead Ads
The next step involves setting up the trigger in Pabbly Connect. This trigger will activate whenever a new lead is received from Facebook Lead Ads. Select “Facebook Lead Ads” as your trigger application.
- Choose the event as “New Lead Instant”.
- Click the “Connect” button to establish a connection.
- Select your Facebook account and allow access.
After connecting your account, select the Facebook page from which you want to capture leads. Ensure you choose the correct form associated with your leads to ensure accurate data capture.
3. Testing the Trigger with Meta Ads
After setting up the trigger, it’s crucial to test it to ensure it’s functioning correctly. Fill out the Facebook Lead Ads form with the required details such as email, first name, last name, phone number, and city. Then, submit the form.
Once submitted, go back to Pabbly Connect to check if the lead details have been captured. You should see the information displayed in the response section, confirming that the trigger works as expected.
4. Adding the Action to Salesforce CRM
Now that the trigger is successfully set up and tested, the next step is to add the action application, which in this case is Salesforce CRM. Search for Salesforce CRM in Pabbly Connect and select it.
- Choose “Create Contact” as the app event.
- Click the “Connect” button to establish a connection with Salesforce.
- Allow access to your Salesforce account.
After connecting to Salesforce, map the fields from the Facebook Lead Ads response to the corresponding fields in Salesforce. This mapping ensures that the lead data is transferred accurately.
After mapping the fields, save your settings and send a test request to ensure everything is working correctly. Check Salesforce CRM to see if the new lead appears with the correct details.
Refresh the contacts page in Salesforce, and you should see the new lead reflected there, confirming that the integration between Meta Ads and Salesforce CRM via Pabbly Connect is successful.
This automation will now allow you to seamlessly manage leads from your Meta Ads into Salesforce CRM, enhancing your business efficiency.
In this tutorial, we explored how to use Pabbly Connect to integrate Meta Ads with Salesforce CRM. By following these steps, you can automate lead management effortlessly, enhancing your business operations.
