To start automating issue reporting, access Pabbly Connect by visiting pabbly.com/connect. If you’re a new user, create a free account to get started. Pabbly Connect offers 100 free tasks every month, allowing you to set up your automation without any cost.
Once logged in, you can create a new workflow. This workflow will capture responses from Google Forms and automate the process of creating tickets in Zoho Desk while sending notifications via WhatsApp. Ensure you have your Google Form ready for integration.
2. Integrating Google Forms with Pabbly Connect
The first step in your automation is to capture responses from Google Forms using Pabbly Connect. Open your Google Form, navigate to the “Responses” tab, and link it to a new Google Sheets document by clicking on the “Create Spreadsheet” icon.
  • Open your Google Form and go to the “Responses” tab.
  • Click on the “Create Spreadsheet” icon to link responses to a new Google Sheets document.
  • Install the Pabbly Connect Webhooks add-on from Google Sheets.
After installing the add-on, go to “Extensions,” select “Pabbly Connect Webhooks,” and set up the initial configuration. You will need to paste the webhook URL provided by Pabbly Connect and select the trigger column, usually the last column of your sheet.
3. Creating Tickets in Zoho Desk
With Google Forms integrated, the next step is to create tickets in Zoho Desk using Pabbly Connect. In your workflow, add a new action step for Zoho Desk. You will need to connect your Zoho account by entering your domain and authorizing the connection.
Once connected, you will set up the ticket creation process. Enter the subject, description, and other required fields dynamically using the data captured from Google Forms. Ensure that the ticket’s priority is set appropriately and that it reflects the urgency of the issue reported.
4. Sending Notifications via WhatsApp
The final step in your automation is to notify users via WhatsApp using Pabbly Connect. Add a new action step for Pabbly Chatbot or WhatsApp Cloud API in your workflow. This step will send a message to the user who reported the issue, including the ticket ID and details.
  • Select the connection type (Pabbly Chatbot or WhatsApp Cloud API).
  • Enter the phone number of the user who reported the issue.
  • Compose a message that includes the ticket ID and problem description.
After setting this up, test the entire workflow by submitting a response through your Google Form. You should see a new ticket created in Zoho Desk and a notification sent via WhatsApp instantly.
5. Conclusion
In this tutorial, we demonstrated how to automate issue reporting using Pabbly Connect, integrating Google Forms, Zoho Desk, and WhatsApp Cloud API. This process streamlines communication and ensures that issues are addressed promptly, enhancing your team’s efficiency.
By following these steps, you can easily set up this automation without any technical skills. With Pabbly Connect, you can create numerous automations tailored to your business needs.
In summary, using Pabbly Connect allows you to seamlessly integrate various applications, enhancing your workflow and improving response times for issue reporting.
