To automate Facebook posts with AI and human approval, you first need to access Pabbly Connect. Open a new tab and search for pabbly.com/connect to reach the Pabbly Connect landing page.
Click on the button for a free trial. Fill in your details to sign up and log into your account. Once logged in, open the workflow builder to get started with your automation process.
2. Setting Up the Schedule in Pabbly Connect
In this step, you will set up the schedule for your Facebook posts using Pabbly Connect. Choose ‘Schedule’ as the trigger event and select ‘Schedule Workflows’.
  • Select the frequency: weekly, monthly, or daily.
  • For example, choose Wednesdays and Sundays at 1 PM for posting.
After making your selections, click the ‘Save’ button to confirm your schedule. This will ensure that your posts are created at the specified times.
3. Integrating AI Tools with Pabbly Connect
Next, you will integrate AI tools using Pabbly Connect. Select any AI tool you wish to connect, such as OpenAI or Gemini. To connect, navigate to ‘Add a new connection’ and input your API key.
  • You can obtain the API key from the respective AI tool’s dashboard.
  • Click on ‘Create new secret key’ and fill out the required fields.
Once connected, select your model and provide the necessary prompt. Click ‘Save and send test request’ to retrieve the content that will be posted on Facebook.
4. Adding Human Approval in the Workflow
To ensure quality control, you will add a human approval step using Pabbly Connect. Introduce the ‘Human-in-the-loop’ event and choose ‘Request approval’. Select how you want to receive the approval request, either via email or another trigger workflow.
  • If you prefer email, input the recipient’s email address.
  • Map the approval message with the AI-generated content.
This mapping allows you to dynamically pull content from the previous step. After setting up, click ‘Save and send test request’ to initiate the approval process. You will receive a notification for approval or rejection.
5. Posting to Facebook Using Pabbly Connect
Finally, you will set up the Facebook posting action in Pabbly Connect. Add the Facebook application and connect with your Facebook account by clicking ‘Add a new connection’. Ensure you are logged in to your Facebook account.
  • Select the Facebook page where you want to post.
  • Input the AI-generated message and any URLs you want to include.
Click ‘Save and send test request’ to finalize your Facebook post. Once the workflow is set up, it will run automatically, allowing you to manage content seamlessly with human verification.
This tutorial provided a step-by-step guide on how to automate Facebook posts using Pabbly Connect with AI and human approval. With this setup, you can ensure quality content is shared on your social media channels effortlessly.
