To start integrating Zoho CRM with Google Sheets and Twilio, you’ll first need to access Pabbly Connect. Open a new tab and navigate to the Pabbly Connect landing page.
If you are a new user, sign up for a free account. Upon signing up, you will receive 100 free tasks to utilize for your automation setup. This will allow you to create the integration without any initial costs.
2. Setting Up the Zoho CRM Trigger in Pabbly Connect
The first step in this integration is setting up the trigger in Pabbly Connect. Select Zoho CRM as your trigger application and choose the event “New Module Entry” to capture new contacts.
  • Select the module for contacts in Zoho CRM.
  • Click on “Send Test Request” to capture the last created contact.
  • Make sure to set the trigger time to every 10 minutes.
Once the trigger is set, Pabbly Connect will automatically search for new contacts in Zoho CRM based on the defined trigger time. This ensures that you receive updates without manual intervention.
3. Sending SMS Notifications Using Twilio
After capturing the contact details from Zoho CRM, the next step is to set up Twilio to send SMS notifications. In Pabbly Connect, select Twilio as your action application and choose the “Send SMS” action.
  • Enter your Twilio Account SID and Token from the Twilio dashboard.
  • Map the SMS body to include the name of the new contact.
  • Specify the sender’s number and the recipient’s phone number.
By completing this setup, Pabbly Connect will ensure that every new contact added to Zoho CRM receives a timely SMS notification, enhancing customer engagement.
4. Recording Contact Details in Google Sheets
The final step in this integration process is to record the contact details in Google Sheets. In Pabbly Connect, select Google Sheets as your action application and choose the “Add New Row” action.
  • Select the specific spreadsheet and sheet where you want to store the data.
  • Map the contact’s full name, email, and phone number into the corresponding fields.
  • Click on “Save and Send Test Request” to verify the setup.
Once this is configured, Pabbly Connect will automatically log every new contact into Google Sheets, providing a systematic record of your customer data.
5. Benefits of Automating Customer Management
Integrating Zoho CRM with Google Sheets and Twilio using Pabbly Connect offers numerous benefits. First, it allows for instant communication with leads, ensuring they feel valued and engaged.
  • Enhances customer engagement through timely SMS notifications.
  • Creates a backup database in Google Sheets for easy data retrieval.
  • Streamlines customer management processes, saving time and resources.
By automating these tasks, Pabbly Connect helps businesses maintain reliable communication with their customers and ensures that all contact details are systematically recorded.
In conclusion, using Pabbly Connect to integrate Zoho CRM with Google Sheets and Twilio streamlines customer management and enhances communication. This setup ensures that every new lead is promptly contacted and recorded, making it a valuable asset for any business.
