To begin automating your Bravo contacts, access Pabbly Connect by navigating to its official website. You will find options to sign up or log in based on your existing account status.
If you are a new user, click on the “Sign Up Free” option. This allows you to explore Pabbly Connect with 100 free tasks each month. For existing users, simply log in to your account to start creating automations.
In this step, you will set the trigger application in Pabbly Connect. This is crucial as it initiates the workflow. Select Typeform as your trigger application and choose the event as “New Entry”.
- Select “New Entry” from the Typeform options.
- Click the “Connect” button to establish a connection.
- Authorize Pabbly Connect to access your Typeform account.
After establishing the connection, select the specific form (e.g., “Lead Generation Form”) from which you want to receive new leads. This sets the stage for the automation to function effectively.
3. Capturing Lead Details from Typeform
Once the trigger is set, the next step in Pabbly Connect involves capturing lead details. Fill out your Typeform with sample data, such as first name, last name, and email address.
After submitting the form, return to Pabbly Connect to verify if the lead details have been captured successfully. You should see a response that includes all fields you filled out in the Typeform.
- First Name: Demo
- Last Name: User
- Email: [email protected]
This confirms that Pabbly Connect has successfully integrated your Typeform as the trigger application, ready to send data to Bravo.
4. Creating a Contact in Bravo Using Pabbly Connect
With the lead details captured, the next step is creating a contact in Bravo. In Pabbly Connect, choose Bravo as your action application and select the event as “Create or Update Contact”.
You will need to connect your Bravo account by entering the domain and API key. To find these, log in to your Bravo account, navigate to settings, and generate a new API key if necessary.
- Enter your Bravo domain.
- Copy and paste the generated API key into Pabbly Connect.
- Map the fields from Typeform to Bravo (e.g., email, first name, last name).
After mapping, click “Save and Send Test Request” to finalize the integration. You should see a confirmation response indicating that the contact has been successfully created in Bravo.
5. Conclusion: Automate Your Bravo Contacts with Pabbly Connect
Using Pabbly Connect to automate contact creation in Bravo not only saves time but also streamlines your workflow. By following these steps, you can ensure that every new lead from Typeform is automatically added to your Bravo account.
This integration highlights the power of Pabbly Connect as a central platform for automating business tasks. Start using it today to enhance your productivity and efficiency.
