To automate WhatsApp messaging, the first step is to access Pabbly Chatflow. Open your browser and visit pav.com/chatflow to reach the homepage.
If you are new to Pabbly Chatflow, click on “Sign Up for Free” to create an account. Existing users can simply sign in. Once logged in, you will see various options available in the dashboard.
2. Setting Up WhatsApp Broadcast in Pabbly Chatflow
After accessing Pabbly Chatflow, navigate to the “Broadcast” feature. This feature allows you to send bulk WhatsApp messages efficiently. Before proceeding, ensure you have a message template ready for use.
  • Select the “Broadcast” option from the dashboard.
  • Click on the “Add Broadcast” button to create a new broadcast.
  • Choose “Broadcast Campaign” as the type.
Once you have set up the broadcast type, provide a name for your campaign, like “Nail Offer.” This name will help you identify the broadcast later.
3. Uploading Your Contact List to Pabbly Chatflow
To send messages, you need to upload a contact list. If your contacts are in Google Sheets, download them as a CSV file first. Then, in Pabbly Chatflow, you can upload this CSV file directly.
Alternatively, if you already have contacts in Pabbly Chatflow, select them from the existing list. You can also refine your audience by excluding specific contacts or groups.
4. Configuring Your Message Template in Pabbly Chatflow
With your contacts uploaded, the next step is to configure your message template. In Pabbly Chatflow, you can either use a pre-approved template or create a regular message. Make sure your template is approved by Meta to avoid any issues.
  • Select the message type from the dropdown.
  • Attach any images you want to include with your message.
  • Test the message by sending a test broadcast to your WhatsApp number.
This testing ensures that everything looks good before sending it to your audience.
5. Scheduling and Sending Your WhatsApp Broadcast
After testing your message, you can schedule your broadcast. In Pabbly Chatflow, you can choose to send the message immediately or select a future date and time for scheduling.
Make sure to turn on the automatic retry option if you want to resend messages to any failed contacts. Once everything is set, click on “Add Broadcast” to finalize your campaign.
In summary, using Pabbly Chatflow to automate WhatsApp messaging can significantly streamline your communication process. This tutorial provided a step-by-step guide to set up broadcasts efficiently.
