To start automating WhatsApp broadcasts, you first need to access Pabbly Connect. This platform allows you to connect various applications seamlessly, enabling efficient marketing strategies.
Open your browser and navigate to Pabbly Connect by typing pabbly.com. Once on the homepage, sign in or create an account. After logging in, you will be directed to the dashboard where all integrations can be managed.
2. Connecting WhatsApp with Pabbly Connect
Connecting WhatsApp to Pabbly Connect is essential for sending bulk messages. You will need your WhatsApp Business number to proceed. Click on the “Add WhatsApp Number” button in the dashboard.
- Select your preferred method to connect, either through scanning a QR code or manual entry.
- Ensure your WhatsApp Business App is set up correctly for integration.
Once connected, you can begin utilizing the features of Pabbly Connect to automate your messaging tasks effectively.
3. Uploading Contacts to Pabbly Connect
To send messages, you need to upload your contacts to Pabbly Connect. Click on “Add Contact” and then select the “Add Bulk Contacts” option. You can upload up to 200,000 contacts at once.
- Prepare a CSV file with your contact details from Google Sheets or Microsoft Excel.
- Drag and drop your CSV file into the upload section.
After uploading, map the fields such as name and phone number to ensure correct data association. This step is crucial for personalized messaging.
4. Creating Message Templates in Pabbly Connect
Next, you need to create message templates that will be sent to your contacts. Navigate to the “Templates” section and click on “Create Template”. Choose the category for your template, such as Marketing.
- Give your template a name and select the language.
- Include variables for dynamic content, such as customer names.
Once your template is ready, save it to use in your broadcasts. This allows for customized messages that resonate with your audience.
5. Broadcasting Messages Using Pabbly Connect
With your contacts uploaded and templates created, you can now broadcast your messages. Click on the “Add Broadcast” button and provide a name for your broadcast.
- Select the contact list you wish to send messages to.
- Choose the template you created earlier for your broadcast.
Test your broadcast by sending a message to your own number first. Once confirmed, you can schedule or send the broadcast immediately. This feature is invaluable for reaching thousands with minimal effort.
In this tutorial, we explored how to automate WhatsApp broadcasts using Pabbly Connect. By integrating your contacts and templates, you can efficiently market your products and services. Automating your messaging can significantly enhance your business outreach.
