To automate appointment queries, start by accessing Pabbly Connect. This platform acts as a bridge between various applications, enabling seamless integration.
Visit the Pabbly Connect website and sign up for an account. Once registered, you can log in to your dashboard, where you can set up your automation workflows.
2. Setting Up Pabbly Chatbot for WhatsApp Integration
Next, you need to configure the Pabbly Chatbot for your WhatsApp integration. This will allow your AI assistant to respond to appointment queries effectively.
  • Open your browser and navigate to chatbot.pabbly.com.
  • Add your WhatsApp number to your Pabbly Chatbot account.
  • Select the AI Assistant option from the left menu.
After setting up your WhatsApp number, you can begin creating your AI assistant. This assistant will handle appointment queries from your clients.
3. Configuring Your AI Assistant with Pabbly Connect
Now, let’s configure the AI assistant using Pabbly Connect. Here, you will set parameters that dictate how your assistant responds to queries.
Start by selecting the type of AI instructions you want to use. This is crucial for ensuring your assistant provides accurate responses. You can adjust the creativity level by setting the temperature, which ranges from 0 to 1.
  • Set the temperature to 0.5 for balanced responses.
  • Choose OpenAI as your AI provider and select the GPT 5.4 model.
With these settings, your AI assistant will be well-equipped to handle various appointment-related inquiries.
4. Integrating OpenAI API with Pabbly Connect
To enhance your AI assistant’s capabilities, integrate the OpenAI API using Pabbly Connect. This step is essential for enabling advanced functionalities.
Obtain your API key from OpenAI’s API keys section. Once you have the key, input it into the designated field in Pabbly Connect.
  • Click on ‘Create New Secret Key’ in OpenAI.
  • Copy the generated key into Pabbly Connect.
After saving the API key, your AI assistant will be connected to OpenAI, allowing it to generate accurate responses to appointment queries.
5. Finalizing Your AI Assistant Setup
Finally, finalize the setup of your AI assistant using Pabbly Connect. This includes customizing the appearance and behavior of your assistant.
Set up the header and footer messages, and configure your knowledge base to ensure the assistant has the information it needs to respond effectively.
  • Provide a knowledge base in .txt or .pdf format.
  • Adjust the chat window title to match your branding, such as “Bright Smile”.
Once everything is configured, activate your AI assistant. You can also embed it into your website using the provided code snippet.
In this tutorial, we explored how to automate appointment queries using Pabbly Connect and a WhatsApp AI Assistant. By following these steps, you can create a responsive AI assistant tailored to your business needs.
Utilizing Pabbly Connect allows for seamless integration with various applications, making it easier to manage client interactions and improve efficiency.
