To automate the process of syncing Google Sheets with Airtable, you first need to access Pabbly Connect. If you’re a new user, simply go to pabbly.com/connect and create a free account. This allows you to explore the features with 100 free tasks each month.
Once logged in, you will land on the Pabbly Connect dashboard. Here, you can manage all your automation workflows. To create a new workflow, click on the “+ Create Workflow” button. This is where the integration setup begins.
After accessing the dashboard, you will want to create a new workflow in Pabbly Connect. For this tutorial, select the “Quick Builder” option to streamline the process. Enter a prompt like “autosync Google Sheets to Airtable database,” and the system will analyze your request.
- Select the trigger as “New or Updated Spreadsheet Row” from Google Sheets.
- Choose the action as “Create Record” in Airtable.
Once you finalize your selections, click on the “Approve and Create” button. This confirms the workflow setup, and you can now proceed to connect your Google Sheets account.
To establish a connection between Google Sheets and Pabbly Connect, you will need a webhook URL. Click on the Google Sheets application in your workflow to get this URL. Copy it and then click on the “Capture Webhook Response” button.
Next, navigate to your Google Sheets account. Open the spreadsheet containing your customer records and click on the “Extensions” menu. From there, select “Add-ons” and then “Get Add-ons”. Search for “Pabbly Connect Webhooks” and install it. After installation, click on the add-on and select “Initial Setup”.
4. Setting Up the Webhook in Google Sheets
In the Initial Setup of the Pabbly Connect Webhook, paste the copied webhook URL. You will also need to specify the trigger column, which is the last column where data will be added. For example, if your last data column is H, enter H in the designated field.
- Click the “Send Test” button to verify the connection.
- Ensure the “Send on Event” option is active to receive new data.
Once the test data is sent successfully, you will see a confirmation in Pabbly Connect. This indicates that your Google Sheets is now effectively connected to the platform, ready for automation.
5. Mapping Data to Airtable
Now that your Google Sheets is connected to Pabbly Connect, you can set up Airtable as the action application. Click on the Airtable application in your workflow and select “Connect”. Then, create a new connection and grant access to your Airtable account.
After successful connection, select the base you wish to use, such as “Google Sheet Data”. You will then need to map the fields from your Google Sheets to the corresponding fields in Airtable. This mapping is crucial for ensuring that the data is transferred correctly.
- Use the slash (/) to access the mapping options.
- Map all relevant fields to ensure dynamic data transfer.
Finally, click on the “Save and Send Test Request” button to confirm that the mapping works. You should see a new record created in Airtable based on the data from Google Sheets, completing the integration process.
In this tutorial, we demonstrated how to automate the syncing of Google Sheets rows to Airtable using Pabbly Connect. This integration streamlines your workflow and saves valuable time. By following the steps outlined, you can effectively manage your data transfer between these applications effortlessly.
