To start integrating Google Sheets with Zoho CRM, the first step is to access Pabbly Connect. You can do this by navigating to the Pabbly website and selecting the ‘Sign Up Free’ option if you are a new user.
If you’re an existing user, simply click on ‘Sign In’. After logging in, you’ll be directed to the workflow page where you can create your automation. Pabbly Connect allows you to manage and automate your business processes efficiently, making it the perfect choice for this integration.
2. Setting Up the Trigger with Google Sheets
In this section, we will set up the trigger in Pabbly Connect to initiate the automation when a new entry is made in Google Sheets. Start by selecting Google Sheets as your trigger application.
- Choose the event as “New or Updated Spreadsheet Row”.
- Click the “Connect” button to generate a webhook URL.
Next, head to your Google Sheets, navigate to the Extensions menu, and select “Pabbly Connect Webhooks”. Choose “Initial Setup” and paste the webhook URL you copied earlier. Enter the trigger column (for example, column D) and click “Submit”. This will establish the connection between Google Sheets and Pabbly Connect.
3. Sending Test Data to Pabbly Connect
Once the webhook setup is complete, it’s time to send test data to Pabbly Connect. In your Google Sheets, enter a new lead with details such as full name, email, and phone number. Then, click on “Send Test” in the Pabbly Connect interface.
This action will send the test data to Pabbly Connect, and you should see a confirmation message indicating that the data was received successfully. Ensure that the test data reflects the fields filled in your Google Sheets.
4. Setting Up the Action with Zoho CRM
Now that we have our trigger set up, we will configure the action in Pabbly Connect to create a new contact in Zoho CRM. Select Zoho CRM as your action application and choose the event “Create Contact”.
- Click the “Connect” button and enter your Zoho CRM domain.
- Authorize Pabbly Connect to access your Zoho CRM account.
- Map the fields from the Google Sheets response to the Zoho CRM fields.
For mapping, you can select the fields from the Google Sheets response to dynamically fill in the contact details in Zoho CRM. This ensures that every new entry is automatically added without manual input, streamlining your workflow.
5. Finalizing the Integration
After mapping the fields, click on “Save and Send Test Request” in Pabbly Connect. You should receive a confirmation that a new contact has been created in your Zoho CRM account. Check your Zoho CRM contacts page to verify that the new lead appears.
This automation significantly reduces manual efforts as every new lead added to your Google Sheets is automatically synced to Zoho CRM. With Pabbly Connect, you can easily manage and automate various applications, enhancing your business efficiency.
In this tutorial, we demonstrated how to sync Google Sheets with Zoho CRM using Pabbly Connect. This integration automates the transfer of data, saving you time and effort while improving data accuracy.
