1. Accessing Pabbly Connect to Start Automation
To begin automating your Facebook Lead Ads with Brevo, the first step is to access Pabbly Connect. Open your browser and navigate to pabby.com/connect. Here, you will find options to sign in or sign up for free.
If you’re new, click on “sign up for free” to get 100 free tasks each month. Existing users can simply sign in. After logging in, you will see the dashboard where you can access all Pabbly applications, including Pabbly Connect.
Once you are on the dashboard of Pabbly Connect, you need to create a workflow to connect Facebook Lead Ads and Brevo. Click on “Create from scratch” to start a new workflow.
- Select the trigger: New Lead from Facebook Lead Ads.
- Set the action to create or update a contact in Brevo.
After setting up the trigger and action, review your workflow and click on “Approve and create” to finalize it. This step is crucial as it establishes the connection between your Facebook Lead Ads and Brevo through Pabbly Connect.
3. Setting Up the Trigger for Facebook Lead Ads
Next, you need to configure the trigger in Pabbly Connect. Click on “Connect with Facebook Lead Ads” and select your Facebook account. Grant access to allow Pabbly Connect to fetch data from your Facebook account.
Once connected, choose the page where your lead ads are running, such as “Prime Properties,” and select the lead generation form. This setup allows Pabbly Connect to automatically capture leads generated from your Facebook ads.
4. Testing the Integration with a Test Lead
After setting up the trigger, it’s essential to test the integration. Use the Meta Lead Ads Testing Tool to generate a test lead. Fill in the required fields like name, email, and phone number, and submit the form.
- Select the page “Prime Properties” in the testing tool.
- Enter dummy details for the test submission.
Check back in Pabbly Connect to see if the test lead was successfully captured. This step ensures that your automation is functioning correctly before going live.
5. Finalizing the Action in Brevo
The final step is to configure the action in Pabbly Connect. Here, you will connect your Brevo account by entering the domain and API key. This allows Pabbly Connect to create a new contact in Brevo whenever a new lead is captured.
Map the data from the test lead to the corresponding fields in Brevo. For instance, map the email address from the lead to the email field in Brevo. After configuring all necessary fields, click “Save and send request” to complete the integration.
In this tutorial, we demonstrated how to automate the integration of Facebook Lead Ads and Brevo using Pabbly Connect. By following these steps, you can efficiently manage your leads and enhance your CRM capabilities.
