To begin using Pabbly Connect, open a new tab and type in the URL: pub.com/connect. This will take you to the Pabbly Connect homepage where you can either sign in or sign up for a free account.
If you’re a new user, click on the “Sign Up Free” button to create an account. You will receive 100 free tasks every month to explore the features of Pabbly Connect. Existing users can simply log in to access the workflow page.
Once logged in, navigate to the workflow page in Pabbly Connect. Here, you will set up the automation to post from Facebook to Telegram. The first step is to select the trigger application, which in this case is Facebook Pages.
  • Select “Facebook Page” as the trigger application.
  • Choose the event as “New Post” to initiate the workflow.
  • Click on the “Connect” button to establish a connection.
After establishing the connection, select the Facebook page you want to monitor for new posts. Once selected, click “Save and Send Test Request” to ensure the connection works properly.
3. Testing the Facebook Trigger in Pabbly Connect
With the trigger set up, it’s time to test the connection. Go to your Facebook page and create a new post. For instance, title it “Consistency Changes Everything” and add an image to it.
After creating the post, return to Pabbly Connect. You should see the response indicating that the new Facebook post has been detected. This confirms that the trigger is functioning correctly.
4. Setting Up the Action to Notify Telegram
Next, you will configure the action application, which is Telegram. Select “Telegram Bot” as the action application in Pabbly Connect.
  • Choose the event “Send a Text Message”.
  • Click on “Connect” and create a new connection.
  • Enter the bot token obtained from the BotFather in Telegram.
Once the connection is established, enter the chat ID of the Telegram group where you want to send the notifications. You can get the chat ID by adding the bot to the group and promoting it to admin.
5. Mapping Data and Sending Notifications
In this step, you will map the data from the Facebook post to the Telegram message. In Pabbly Connect, you can dynamically insert the post title and link into the message.
For mapping, select the fields from the previous Facebook response. Set the message format to HTML and click “Save and Send Test Request”. You should receive a confirmation that the message has been sent to your Telegram group.
Now, check your Telegram group to see if the notification appears as expected. This completes the automation process, allowing you to notify your audience on Telegram whenever you post on Facebook.
Using Pabbly Connect, you can effortlessly automate the process of sharing Facebook posts to Telegram. This integration is perfect for content creators and businesses looking to keep their audience updated in real-time. Start using Pabbly Connect today to enhance your social media strategy!
