To start integrating WhatsApp with Facebook Leads, you need to access Pabbly Connect. Open your browser and search for Pabbly.com Connect. This will take you to the home page of Pabbly Connect.
If you are a new user, click on ‘Sign Up Free’ to create an account and get 100 free tasks every month. Existing users can simply sign in. Once logged in, navigate to the dashboard to access all applications.
In Pabbly Connect, you will create a new workflow to automate the process. Click on ‘Create New Workflow’ to begin. You can either create from scratch or use the AI workflow builder. For this tutorial, we will use the AI builder.
  • Select ‘When a new lead comes in from Facebook Ads.’
  • Choose ‘Send WhatsApp Message’ as the action.
  • Preview your workflow to ensure correctness.
After confirming the workflow, click on ‘Create’ to finalize it. You will receive a workflow link confirming successful creation.
3. Setting Up the Facebook Leads Trigger
The next step is to set up the trigger for Facebook Leads in Pabbly Connect. Click on ‘Connect with Facebook Lead Ads’ to give Pabbly access to your Facebook account. This ensures your data is secure.
Once connected, select your Facebook page and the specific lead generation form you want to use. Make sure to set the response format to simple for better organization. After selecting, click on ‘Save and Send Request’ to wait for a webhook response.
4. Sending WhatsApp Messages Automatically
Now, you will set up the WhatsApp message that will be sent to new leads using Pabbly Connect. Select the WhatsApp communication platform and enter your API token to connect. This allows Pabbly to send messages directly to your leads.
  • Enter the WhatsApp number you want to send messages to.
  • Map the data from the previous step to personalize the message.
  • Input your desired message template.
After entering the details, click on ‘Save and Send Request’ to send the WhatsApp message. You will receive a success response confirming the message was sent successfully.
5. Conclusion
In this tutorial, we showed you how to integrate WhatsApp with Facebook Leads using Pabbly Connect. This automation allows you to instantly engage with new leads through personalized WhatsApp messages, enhancing your communication strategy.
By following these steps, you can streamline your lead management process and improve customer engagement effectively. Start using Pabbly Connect today for seamless automation!
