1. Create a WhatsApp Chatbot Using Pabbly Connect
To start the integration with Pabbly Connect, you first need to create a WhatsApp chatbot. This chatbot will collect leads by interacting with users. Begin by accessing the Pabbly Chatflow platform at pabbly.com/chatflow.
Once logged in, you can initiate the chatbot creation process. Follow these steps to set up your WhatsApp chatbot:
  • Log in to your Pabbly Chatflow account.
  • Create a new flow and set the trigger keywords to initiate the chatbot.
  • Use drag-and-drop elements to build your flow, starting with a welcome message.
This sets the foundation for collecting leads. Once the chatbot is configured, you can test it by sending a message to your WhatsApp number.
2. Collect Lead Data via WhatsApp
The next step involves collecting specific lead data through the chatbot created with Pabbly Connect. As users interact with the bot, they will be prompted to provide essential information.
Here’s how the lead data collection occurs:
  • Prompt users for their full name, business name, email address, and monthly marketing budget.
  • Utilize the ask question node to gather this information and store it in custom fields.
  • Confirm the collected data with a summary message to the user.
This process ensures that you gather all necessary details from your leads, ready for the next step in the workflow.
3. Integrate Slack Using Pabbly Connect
After collecting lead data, the next crucial step is to integrate Slack using Pabbly Connect. This integration allows you to automatically notify your team about new leads.
Follow these steps to set up the integration:
  • In Pabbly Connect, select Pabbly Chatflow as the trigger application.
  • Choose the event as ‘New Message Received’ and copy the webhook URL provided.
  • In your chatbot flow, use the API request node to send data to the copied webhook URL.
This integration ensures that every time a lead is collected, a notification is sent to your Slack channel, streamlining your lead management process.
4. Send Notifications to Slack
Once the integration is set up, you can configure how notifications are sent to Slack using Pabbly Connect. This step is essential for keeping your team updated in real-time.
Here’s how to send notifications:
  • Select Slack as the action application in Pabbly Connect.
  • Choose the event ‘Send Channel Message’ and enter your Slack token to authenticate.
  • Map the lead details collected from the chatbot to the Slack message format.
This setup allows you to send a detailed message to your Slack channel every time a new lead is received, ensuring your team is always in the loop.
5. Finalize Your Pabbly Connect Integration
The final step in this process is to finalize your integration using Pabbly Connect. This involves saving your workflow and ensuring everything is functioning as expected.
To complete the integration:
  • Test the entire flow by sending a lead through your WhatsApp chatbot.
  • Check your Slack channel for the notification to confirm successful integration.
  • Save your workflow in Pabbly Connect for future use.
With these steps completed, your WhatsApp leads will now be automatically sent to your Slack channel, enhancing your team’s efficiency in managing leads.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate WhatsApp leads into Slack. By following these steps, you can automate your lead management process effectively.
Utilizing Pabbly Connect ensures that you never miss a lead and can keep your team informed in real-time.
