To automate email confirmations, you begin by accessing Pabbly Connect. Open your browser and navigate to pabbly.com/connect. This platform allows you to connect various applications seamlessly.
Upon reaching the homepage, you will see two options: “Sign In” and “Sign Up Free.” If you are new to Pabbly Connect, click on “Sign Up Free” to create an account. Existing users can simply sign in to access their dashboard.
Once you are logged into Pabbly Connect, navigate to the dashboard to create a new workflow. Click on “Create from Scratch” or use the AI-based workflow builder for a guided setup.
  • Select the trigger as “New Entry” from Typeform.
  • Choose the action as “Send Email” via Gmail.
After selecting these options, you can preview the workflow created by Pabbly Connect. If everything looks correct, approve and create the workflow to proceed.
The next step involves setting up the trigger for your workflow. In Pabbly Connect, you will need to connect to Typeform. This requires granting access to ensure that your data remains secure.
After connecting, select your registration form from the drop-down menu. For the response format, choose “Simple” to keep the data organized. Click on “Save and Send Test Request” to test the connection.
  • Enter dummy details in the Typeform registration form.
  • Make a test submission to verify the trigger setup.
After successfully submitting the form, check Pabbly Connect for a successful response, confirming that the trigger is functioning correctly.
4. Configuring the Email Action in Pabbly Connect
Now that the trigger is set, proceed to configure the email action in Pabbly Connect. You will connect to your Gmail account by clicking on “Sign In with Google” and selecting your account.
For the email setup, specify the sender name, sender email, and recipient email. Instead of manually entering the recipient’s email, use the mapping feature to dynamically insert the email address from the trigger response.
  • Set the email subject as “Your Registration is Confirmed. See You There!”
  • Input your HTML coded email content to enhance visual appeal.
Finalize the email configuration by selecting “HTML” for the content type. Click on “Save and Send Test Request” to send a test email to the registrant’s Gmail account.
5. Summary of the Automation Process Using Pabbly Connect
In this tutorial, you’ve learned how to automate email confirmations for Typeform submissions using Pabbly Connect. The integration process ensures that every new registration triggers an instant email response.
To summarize, you set up a trigger for new entries in Typeform and configured an email action via Gmail. This seamless automation enhances your registration workflow, providing immediate confirmation to registrants.
With Pabbly Connect, you can create various automations to streamline your business processes. Explore the platform further to discover additional capabilities.
In conclusion, using Pabbly Connect, you can efficiently automate email confirmations for Typeform registrations. This setup not only saves time but also enhances user experience by providing instant feedback to registrants. Start automating your workflows today with Pabbly Connect!
