To start integrating Pabbly, Webook, Pab, Google, and Gmail, you need to access Pabbly Connect. Open your browser and search for Pabbly.com, then navigate to Pabbly Connect.
If you are a new user, click on “Sign up for free” to create an account. Existing users can simply sign in. After signing in, you will be directed to the Pabbly Connect dashboard where you can create new workflows.
Once you’re on the Pabbly Connect dashboard, you can start creating a workflow that connects your applications. Click on “Create New Workflow”. This is where Pabbly Connect allows you to set up the automation process.
  • Choose a name for your workflow.
  • Select the trigger application, which in this case is Webook.
  • Set the event to “Payment Captured”.
After setting the trigger, you will now choose the action application. Here, select Gmail to send a confirmation email. This is how Pabbly Connect automates your workflow, ensuring instant communication with your customers.
3. Setting Up Webook in Pabbly Connect
Next, you will set up Webook to capture the payment information. Go to your Razorpay account and navigate to the developer section to access Webook settings. Here, you will add a new Webook URL provided by Pabbly Connect.
Copy the Webook URL from Pabbly Connect and paste it into the Webook settings in Razorpay. Select the event type as “Payment Captured” and click on create Webook. This step is crucial as it links your payment processing with Pabbly Connect.
4. Sending Confirmation Email Using Gmail
After setting up the Webook, it’s time to configure Gmail to send confirmation emails. Back in Pabbly Connect, select Gmail as your action application. Click on “Sign in with Google” to connect your Gmail account.
  • Enter the sender name as your brand name.
  • Map the recipient email address from the payment response.
  • Set the email subject to “Payment Successful: Your Order is Confirmed”.
By mapping the correct data, Pabbly Connect ensures that each customer receives a personalized confirmation email, enhancing their experience.
5. Testing the Integration
Finally, you need to test the entire integration to ensure everything works smoothly. Make a test payment through your Razorpay payment page. This will trigger the Webook and send data to Pabbly Connect.
Check your Gmail account to confirm that the personalized email has been received. This step verifies that your workflow is functioning as intended and that the integration between Pabbly, Webook, Pab, Google, and Gmail is successful.
In this tutorial, we explored how to integrate Pabbly, Webook, Pab, Google, and Gmail using Pabbly Connect. By following these steps, you can automate payment confirmations and enhance customer communication.
