To start integrating WhatsApp leads into Google Sheets, you need to access Pabbly Connect. This platform enables seamless automation between various applications. Begin by visiting the Pabbly website and signing up or logging in.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow to connect your WhatsApp chatbot with Google Sheets. Ensure you have both applications ready to be integrated.
2. Setting Up Your WhatsApp Chatbot with Pabbly Chat Flow
Next, you need to set up your WhatsApp chatbot using Pabbly Chat Flow. This tool allows you to create chatbots without any coding. Begin by accessing the Pabbly Chat Flow page and selecting ‘Create New Flow’.
- Enter a trigger keyword to initiate the chatbot.
- Create a welcome message for users.
- Add buttons for users to explore services.
After setting up the initial flow, you can add more interactions, such as asking for the user’s full name and email. This information will later be sent to Google Sheets via Pabbly Connect.
3. Configuring API Requests in Pabbly Connect
After your chatbot is set up, it’s time to configure API requests using Pabbly Connect. This step is crucial as it allows data to be sent from your WhatsApp chatbot to Google Sheets. In your Pabbly Connect workflow, select the trigger application as Pabbly Chat Flow.
Set the event to ‘New Message Received’ and connect it to your WhatsApp chatbot. You will receive a webhook URL that you need to enter in the API request node of your chatbot. This URL will ensure that data flows correctly between the two applications.
- Select the correct request method (POST).
- Enter the webhook URL in your chatbot settings.
- Map the required fields such as full name, email, and service type.
This setup will ensure that every time a user interacts with your chatbot, their data is captured and sent to Google Sheets via Pabbly Connect.
4. Mapping Data to Google Sheets
Once the API requests are configured, the next step is mapping the data to Google Sheets. In your Pabbly Connect workflow, select Google Sheets as the action application. Choose the event ‘Add New Row’ to insert data into your spreadsheet.
Connect your Google account and select the specific spreadsheet where you want the data to be saved. You will then map the fields from the previous step to the corresponding columns in your Google Sheet.
- Select the spreadsheet named ‘Digital Dynamics Data’.
- Map fields like full name, email, and service type to the correct columns.
- Test the connection to ensure data is flowing correctly.
With this setup, every new lead captured through your WhatsApp chatbot will automatically populate your Google Sheet, thanks to Pabbly Connect.
5. Finalizing and Testing Your Integration
After mapping the data, it’s essential to finalize and test your integration. Ensure that all settings are correctly configured in both Pabbly Connect and your WhatsApp chatbot. Save your flow and run a test by interacting with your chatbot.
Once you submit your information through the WhatsApp chatbot, check your Google Sheet to confirm that the data appears correctly. If everything is set up properly, you should see the new lead information in your specified spreadsheet.
By using Pabbly Connect, you have successfully automated the process of saving WhatsApp leads into Google Sheets. This integration streamlines your workflow and saves valuable time.
In this tutorial, we explored how to integrate WhatsApp leads into Google Sheets using Pabbly Connect. This step-by-step guide simplifies the process of automating lead capture, making it efficient and effective. Start using Pabbly Connect today to enhance your business automation!
