To start automating email responses, the first step is to access Pabbly Connect. Open a new tab and type in the URL: pabbly.com/connect. This will take you to the homepage of Pabbly Connect, where you can sign in or sign up for a free account.
If you’re new to Pabbly Connect, click on the “Sign Up Free” button. This allows you to explore the platform with 100 free tasks each month. If you are an existing user, simply click on “Sign In” to access your dashboard.
2. Setting Up the Workflow in Pabbly Connect
Once you are logged into Pabbly Connect, navigate to the workflow page. Here, you’ll set up the automation that sends emails to your leads after they fill out your website form. The first step is to add a trigger, which is essential for initiating the workflow.
- Select the “Webhook by Pabbly” application.
- Choose the event as “Catch Webhook”.
- Click the “Connect” button to generate a Webhook URL.
Copy the generated Webhook URL and integrate it into your website form code. This connection allows Pabbly Connect to capture data from your form submissions automatically.
3. Testing the Integration with Form Submission
After setting up the Webhook, it’s time to test the integration. Fill out your website form with sample data to simulate a lead submission. For instance, enter a name, email, and phone number, then submit the form.
Return to Pabbly Connect to check if the data has been captured. You should see a response indicating that the details from your form submission have been successfully received. This confirms that the trigger is working correctly.
4. Setting Up Gmail Integration in Pabbly Connect
Now that your trigger is working, the next step is to set up the action app, which in this case is Gmail. Choose Gmail as your action app within Pabbly Connect and select the event as “Send Email”.
- Click the “Connect” button and authorize your Google account.
- Map the recipient’s email address using the data received from the Webhook.
- Fill in the subject and body of the email.
This mapping feature allows Pabbly Connect to dynamically insert the lead’s information into the email, ensuring personalized communication.
5. Finalizing and Testing the Automation
With the Gmail integration set up, it’s time to finalize the automation. Click “Save” and then send a test email to verify that everything is functioning as expected. You should receive the email in your Gmail account with the subject and content you specified.
Once confirmed, your automation is ready to go live. This setup will ensure that every time a lead fills out your website form, they will automatically receive an email response, enhancing user experience and engagement.
By following these steps, you can effectively automate email responses using Pabbly Connect. This not only saves time but also improves communication with your leads, allowing you to focus on growing your business.
