To start automating lead reactivation, you need to access Pabbly Connect. This platform allows you to create workflows that connect different applications seamlessly, ensuring that your leads are re-engaged automatically.
Begin by logging into your Pabbly Connect account. Once logged in, navigate to the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ button to initiate the process.
2. Creating Your Workflow with Pabbly Connect
After you click on ‘Create Workflow’, select the option to create using the Quick Builder. This feature simplifies the process of setting up your workflow in Pabbly Connect.
- Start a new chat by clicking ‘Start Fresh’.
- Input the prompt for your workflow, such as “Create a workflow to automatically send WhatsApp messages through Pabbly Chatflow to cold leads in Google Sheets”.
- Send this prompt to the AI to generate your workflow structure.
Once the workflow is generated, you will see various applications that need to be integrated with Pabbly Connect. Follow the prompts to set up your trigger and action applications.
3. Integrating Google Sheets with Pabbly Connect
Next, you will integrate Google Sheets as the trigger application. This is crucial for pulling in lead data. In Pabbly Connect, select Google Sheets and connect it by signing into your Google account.
Choose the spreadsheet that contains your lead data. For example, select the spreadsheet named “Worksheet” and the sheet titled “Lead Outreach System”. Ensure you set the range to A2:D to capture all relevant data.
4. Setting Up WhatsApp Messaging via Pabbly Connect
After setting up Google Sheets, the next step is to integrate WhatsApp using Pabbly Chatflow. This allows you to send messages to leads based on their status in Google Sheets.
- Connect to Pabbly Chatflow and enter your API token.
- Map the recipient’s WhatsApp number and customize the message using data from Google Sheets.
- Press ‘Save and Send Test Request’ to ensure the message is sent successfully.
This integration is essential as it allows you to automatically send reactivation messages to cold leads, enhancing your follow-up strategy.
5. Finalizing Your Pabbly Connect Workflow
Once all integrations are set, finalize your workflow in Pabbly Connect. Test the entire process to ensure that leads receive their messages as intended.
By automating this workflow, you can ensure that no lead is left unattended, significantly improving your engagement rates. This method not only saves time but also increases your chances of converting cold leads into active customers.
In this tutorial, we explored how to automate lead reactivation using Pabbly Connect with Google Sheets and WhatsApp. By following these steps, you can enhance your sales process and ensure timely follow-ups with leads.
