1. Accessing Pabbly Connect for Blog Automation
To auto-publish SEO blogs, start by accessing Pabbly Connect through your browser. This platform allows seamless integration of various applications to automate your blogging process.
Once on the Pabbly Connect homepage, sign up for a free account. After signing in, navigate to the dashboard where you can create a new workflow. This workflow will automate the process of generating and publishing your blogs.
2. Setting Up Scheduled Workflows in Pabbly Connect
To ensure your blogs are published daily, utilize the scheduling feature in Pabbly Connect. Select the “Schedule by Pabbly” option to set a specific time for your blog to be published.
  • Choose the time you want your blog to be published (e.g., 4 PM).
  • Set the frequency to daily for consistent publishing.
  • Save your settings to activate the schedule.
By setting this schedule, your workflow will run automatically at the specified time without manual intervention.
3. Generating Unique Blog Titles Using OpenAI
Next, you need a unique title for your blog. This is where Pabbly Connect comes in handy by integrating with OpenAI’s ChatGPT. Go to “Connected Apps” and select “Add New Connection” to set up OpenAI.
To generate a title, you will need to input an API key from your OpenAI account. Once connected, choose the GPT-3.5 model and enter a prompt tailored to your travel agency’s needs.
  • Use a prompt that specifies the type of content you want (like travel blogs).
  • Click on “Save and Send Test Request” to generate your title.
After a few seconds, you’ll receive a creative title that will serve as the foundation for your blog content.
4. Creating SEO Blog Content Automatically
Once you have your blog title, it’s time to generate the content. Again, Pabbly Connect will facilitate this integration with OpenAI. Follow the same steps to connect to OpenAI as before.
For this step, modify your prompt to request SEO-optimized content based on the generated title. This will ensure your blog is not only engaging but also ranks well in search engines.
  • Specify that you want the content in HTML format for better presentation.
  • Click “Save and Send Test Request” to receive your SEO blog content.
Within moments, you’ll have the complete blog content ready for publishing.
5. Publishing Your Blog Post on Google Blogger
The final step is to publish the blog post on Google Blogger using Pabbly Connect. Go to the “Connections” section and select “Add New Connection” for Google Blogger.
After signing in with your Google account, select the blog where you want to publish. Map the title and content fields with the data generated from the previous steps.
  • Set the post status to “Draft” to review it before publishing.
  • Save your settings and send a test request to confirm everything is functioning correctly.
After refreshing your Google Blogger account, you’ll see the new blog post ready for your review and publication.
Using Pabbly Connect, you can effortlessly auto-publish SEO blogs in just 3 minutes. This step-by-step process integrates various tools to automate content generation and publishing, saving you time and effort.
