To start automating blog posts, first access Pabbly Connect by visiting pabbly.com/connect. This platform allows you to integrate various applications seamlessly.
Once on the dashboard, you will see options to create workflows. Here, you can set up automation between OpenAI and Google Blogger. Make sure to sign in or create an account to proceed.
2. Setting Up a Scheduled Workflow with Pabbly Connect
In this section, we will set up a scheduled workflow using Pabbly Connect to automate the posting process. Start by selecting “Scheduled by Pabbly” as your trigger application.
  • Choose “Scheduled workflow” as the event.
  • Set the frequency to daily.
  • Select the time to 10:00 AM.
After configuring these settings, save your workflow. This will ensure that the automation runs every day at the specified time, initiating the process of content creation.
3. Integrating OpenAI with Pabbly Connect
Next, we will integrate OpenAI into our workflow using Pabbly Connect. Select OpenAI as your action application and choose “ChatGPT” as the event.
To establish a connection, you will need to input your OpenAI API key. To obtain this key, visit the OpenAI API keys page and create a new secret key. After entering the key in Pabbly Connect, save the connection.
Once connected, you will need to provide a prompt for the AI. For instance, you might use a prompt like “Act as a professional SEO content strategist.” This will guide OpenAI in generating relevant blog titles and content.
4. Creating Content Using OpenAI
Now that OpenAI is integrated, it’s time to create the blog content. Using Pabbly Connect, set up another action step with OpenAI to generate the actual blog post based on the title created previously.
  • Select the same OpenAI connection.
  • Choose “ChatGPT” as the event again.
  • Provide the prompt to generate content based on the title.
Utilizing the mapping feature in Pabbly Connect, you can automatically insert the title generated from the previous step into the prompt, ensuring a seamless flow of information.
5. Posting to Google Blogger with Pabbly Connect
Finally, we will publish the generated content to Google Blogger using Pabbly Connect. Choose Google Blogger as your action application and select “Create Post” as the event.
Connect your Google account to Pabbly Connect and grant the necessary permissions. You will need to specify the blog ID and input the title and content generated by OpenAI.
  • Set the post status to “Published”.
  • Ensure all fields are filled correctly before saving.
Once saved, your blog will automatically post the content created by OpenAI, completing the automation process.
By following these steps, you can effectively automate the process of creating and posting content on Google Blogger using Pabbly Connect. This integration not only saves time but also enhances your content strategy.
