To start automating your Lindin posts, you need to access Pabbly Connect. Open your browser and search for pably.com. This will direct you to the Pabbly Connect homepage.
If you are a new user, click on ‘Sign Up for Free’ to create an account and get 100 free tasks each month. Existing users can simply sign in to their accounts. Once logged in, you will see all the applications available in Pabbly.
In Pabbly Connect, creating a workflow is your next step. Click on ‘Access Now’ for Pabbly Connect and navigate to the dashboard. Here, you can choose to create a workflow from scratch or use the quick builder.
  • Select ‘Create from Scratch’ for a custom workflow.
  • For a quick setup, opt for the ‘Quick Builder’ option.
Once you choose your method, specify your workflow details. For this tutorial, we will use the quick builder to set up a workflow that captures new RSS feed items and shares them on Lindin.
The next step is to set up the trigger in Pabbly Connect. You will need to select the RSS by Pabbly app as your trigger. Choose the ‘New Item in Feed’ option to capture new updates.
After selecting the trigger, input the RSS feed URL. For this tutorial, we will use the latest RSS feed from a popular news source. This setup ensures that every new item published in the feed will trigger the workflow.
4. Connecting Lindin to Pabbly Connect
Now that your trigger is set, it’s time to connect Lindin with Pabbly Connect. Click on ‘Connect with Lindin’ and provide your account details. If you have pre-filled information, simply click on ‘Sign In’. This action successfully connects your Lindin account.
Next, you will need to specify the content that you want to share. Enter the article title and URL dynamically from the previous step. This mapping allows Pabbly Connect to pull the data from the RSS feed and share it as a new post on Lindin.
5. Finalizing Your Automation
With the trigger and action set, your automation in Pabbly Connect is almost complete. Review the details of your workflow to ensure everything is correct. Once verified, click on ‘Save and Send Test Request’ to check if your setup works correctly.
If everything is set up properly, you will receive a successful response. This means your new blog post will automatically be shared on your Lindin account whenever a new item is published in your RSS feed.
In this tutorial, we successfully integrated Pabbly and Lindin using Pabbly Connect. By following these steps, you can automate the sharing of your RSS feed updates on Lindin effortlessly. This automation not only saves time but also enhances your online presence.
