To begin integrating RSS feeds with LinkedIn, first access Pabbly Connect. You can visit the Pabbly website by typing pabby.com in your browser. This platform is essential for creating automated workflows between various applications.
Once on the website, you will see options to sign in or sign up. If you are an existing user, click on the “Sign In” button. New users can register by clicking “Sign Up for Free”. After logging in, navigate to the Pabbly Connect dashboard to start creating your workflow.
After accessing Pabbly Connect, you can create a new workflow. Click on the “Create Workflow” option. Name your workflow something descriptive, like “Post Daily RSS Updates to LinkedIn”. Select a folder for organization, then click on “Create” to initialize the workflow.
  • Click on “Create Workflow”.
  • Select a folder for organization.
Once the workflow is created, you will see a prompt to select your trigger application. This is the first step in the automation process, which will activate the workflow whenever a new event occurs.
3. Setting Up RSS as the Trigger Application
In the trigger application section, select Pabbly Connect and then choose “RSS by Pabbly”. The trigger event you want is “New Item in Feed”. Click on “Connect” to link your RSS feed.
You will need to enter the feed URL from your RSS source. For instance, if you are using the Times of India RSS feed, copy the URL and paste it into the feed URL field. Once done, click “Save and Send Test Request” to verify that the connection works.
  • Select “RSS by Pabbly” as the trigger application.
  • Choose “New Item in Feed” as the trigger event.
  • Enter your RSS feed URL.
After confirming the connection, you will see the latest news fetched from the RSS feed, confirming that the setup is successful.
4. Generating LinkedIn Content with OpenAI
Next, you will want to create an action step to generate content for LinkedIn. Add a new action step in your workflow and select Pabbly Connect again, this time searching for “OpenAI”. Choose “Chat GPT” as the action event and click on “Connect”.
To connect OpenAI, you need an API key. If you don’t have one, follow the prompts to create a new API key. Once connected, select the AI model and enter a prompt that instructs OpenAI on how to generate the content from the RSS feed.
  • Add a new action step for OpenAI.
  • Select “Chat GPT” as the action event.
  • Enter your prompt for content generation.
This prompt should guide OpenAI to create a professional LinkedIn post based on the RSS feed content. Once you have mapped the necessary fields, save and send a test request to ensure everything is functioning correctly.
5. Posting Generated Content to LinkedIn
Finally, you will set up the last action step to post the generated content to LinkedIn using Pabbly Connect. Add another action step and search for “LinkedIn”. Choose the action event “Share Simple Text” and click on “Connect”.
Make sure you are logged into your LinkedIn account to create the connection. Once connected, you will need to map the content generated by OpenAI into the LinkedIn post. Set the visibility to public and save your workflow.
  • Add LinkedIn as the action step.
  • Select “Share Simple Text” as the action event.
  • Map the generated content to the LinkedIn post.
After saving this step, your integration is complete. Now, whenever a new item appears in your RSS feed, it will automatically generate content and post it to your LinkedIn account, showcasing your business updates seamlessly.
In this tutorial, we explored how to integrate RSS feeds with LinkedIn using Pabbly Connect. By following these steps, you can automate your LinkedIn updates effectively and keep your audience informed with fresh content.
