1. Setting Up Pabbly Connect for Google Blogger and Facebook Integration
To automate your blog posting, first, access Pabbly Connect by visiting its official website. If you are a new user, sign up for a free account to explore its features. Existing users can simply log in to their accounts.
Once logged in, navigate to the workflow page. Here, you will set up the automation between Google Blogger and Facebook. This process will significantly reduce the manual effort involved in posting your articles across platforms.
2. Creating a New Blog Post in Google Blogger
Start by creating a new article in your Google Blogger account. Title your post as ‘Beginner’s Guide to Planning Your First Trip’ and provide an engaging description. Once completed, publish the blog.
  • Log in to Google Blogger.
  • Create a new post with a title and description.
  • Publish the post to make it live.
After publishing, wait a few minutes for Pabbly Connect to fetch the new post. This automation allows your blog to be shared seamlessly on Facebook, reaching a wider audience without extra work.
3. Configuring Pabbly Connect Workflow
Now, return to Pabbly Connect and select Google Blogger as your trigger application. Choose ‘New Post Added’ as the event that will initiate the workflow. This step is crucial for linking your blog with Facebook.
Next, build a connection by signing in with your Google account. Allow necessary permissions to enable Pabbly Connect to access your Blogger posts. After establishing the connection, select the specific blog you want to monitor for new posts.
  • Select the trigger application as Google Blogger.
  • Choose the event ‘New Post Added’.
  • Sign in to your Google account to build the connection.
Finally, set the polling interval for Pabbly Connect to check for new posts. Setting it to every 90 minutes ensures timely updates for your Facebook page.
4. Posting the Blog to Facebook Automatically
With your Google Blogger setup ready, it’s time to add Facebook as your action application in Pabbly Connect. Choose ‘Create Page Post’ as the event for this action. This step completes the integration, allowing automatic posting of your blog to Facebook.
Connect to your Facebook account by selecting the page where you want to share the blog. Enter a message for the post, incorporating dynamic fields for the blog title and URL using the mapping feature in Pabbly Connect. This feature allows you to create dynamic content that updates automatically with each new blog post.
  • Choose Facebook as the action application.
  • Select ‘Create Page Post’ as the event.
  • Map the blog title and URL in the message field.
Once done, click on ‘Save and Send Test Request’ to ensure everything is functioning correctly. This will create a test post on Facebook, confirming that your automation setup is successful.
5. Verifying the Integration Success
After setting up the workflow, check your Facebook page to verify that the blog post has been published. Refresh your page and look for the new post with the title and URL of your latest blog article. This confirms that Pabbly Connect has successfully automated the process.
With this integration, every time you publish a new article on Google Blogger, it will automatically appear on your Facebook page. This automation saves you time and effort, allowing you to focus on creating more content.
Utilizing Pabbly Connect for this integration not only streamlines your workflow but also enhances your online presence by reaching more readers efficiently. Now, you can automate multiple applications using the same principles!
By following this tutorial, you can effectively use Pabbly Connect to automate your blog posts from Google Blogger to Facebook. This integration significantly reduces manual tasks and enhances your content’s reach.
