To begin automating the process of creating Salesforce CRM contacts from WhatsApp leads, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website. If you are a new user, click on the “Sign Up Free” option to create an account and receive 100 free tasks each month.
After signing in, navigate to the dashboard. Click on the “Access Now” button under Pabbly Connect to enter the automation workspace. Here, you can create and manage all your workflows efficiently. Click on the “Create Workflow” button to start setting up your automation.
In this step, you will create a new workflow in Pabbly Connect. Enter a descriptive name for your workflow, such as “Auto-create Contacts in Salesforce from WhatsApp Leads”. Choose the appropriate folder for your workflow and click on the “Create” button.
  • Select the folder for organization.
  • Click on “Create” to finalize.
Once the workflow is created, the next crucial step is to set up the trigger. This will allow your automation to activate whenever a new lead comes through your WhatsApp chatbot.
The trigger is the first step in your workflow. In Pabbly Connect, select the application as Pabbly Chatflow. Then, choose the event as “New Message Received”. Click on the “Connect” button, and you will receive a webhook URL along with steps to connect your Pabbly Connect account with Pabbly Chatflow.
Now, go to your Pabbly Chatflow account and access the chatbot flow you have designed. You will need to set the API request using the webhook URL provided by Pabbly Connect. Edit the request method as POST and paste the URL into the designated field.
4. Configuring the API Request in Pabbly Chatflow
In this section, you will configure the API request in Pabbly Chatflow to ensure it communicates effectively with Pabbly Connect. Select the parameters for the API request, including first name, last name, course type, contact number, email, and city name.
  • Set the request method to POST.
  • Input the webhook URL from Pabbly Connect.
  • Map the parameters to the corresponding fields.
After setting up the parameters, click on the “Test” button to ensure the API request is successful. Once confirmed, save the request and ensure the connection between Pabbly Chatflow and Pabbly Connect is established correctly.
5. Integrating Salesforce CRM with Pabbly Connect
Now that your trigger is set up, it’s time to configure the action application. Choose Salesforce as your action application in Pabbly Connect. Select the event as “Create Contact” and click on the “Connect” button. You will have the option to either add a new connection or select an existing one.
Once connected, you will need to map the fields from the previous application (Pabbly Chatflow) to the Salesforce fields. This mapping ensures that the data from WhatsApp leads is correctly transferred to Salesforce CRM. Map the first name, last name, email, contact number, course type, and city name appropriately.
After completing the mapping, click on the “Save and Send Test Request” button to verify that the integration works as expected. If successful, a new contact will be automatically created in your Salesforce CRM whenever a new lead comes through your WhatsApp chatbot.
This tutorial demonstrated how to automate the creation of Salesforce CRM contacts from WhatsApp leads using Pabbly Connect and Pabbly Chatflow. By following these steps, you can streamline your lead management process effectively.
