To start automating tasks in ClickUp using Facebook leads, you first need to access Pabbly Connect. Open a new tab and enter the URL pabbly.com/connect to reach the Pabbly homepage.
If you are a new user, click on the “Sign Up Free” option. This allows you to explore Pabbly Connect with 100 free tasks every month. Existing users can simply log in by clicking “Sign In”.
The next step involves setting up the trigger in Pabbly Connect. The trigger identifies when a new lead is generated from Facebook Ads. Select “Facebook Lead Ads” as your trigger application.
- Choose the event as “New Lead Instant”.
- Click on “Connect” to establish the connection.
- Select the Facebook account and continue.
After connecting, select the Facebook page and form related to your leads. This setup ensures that every new lead is captured by Pabbly Connect.
3. Testing the Trigger with Facebook Leads
After setting up the trigger, it’s crucial to test it. To do this, go to your Facebook Lead Ads and fill out the form with lead details. Submit the form to see if Pabbly Connect captures the data correctly.
Once the form is submitted, check Pabbly Connect for a response indicating that it has received the lead information. This confirms that your trigger is working as expected.
Remember, the successful capture of lead data is essential for the next step of creating tasks in ClickUp.
4. Creating a Task in ClickUp via Pabbly Connect
Now that the trigger is set, you can create a task in ClickUp using Pabbly Connect. Choose ClickUp as your action application and select “Create Task with Custom Fields” as the event.
- Connect to ClickUp by entering your API token.
- Select the workspace and space for the task.
- Map the lead details from Facebook to the task fields.
This mapping allows Pabbly Connect to dynamically insert lead details into the ClickUp task, ensuring that each task is personalized with the lead’s information.
5. Finalizing the Integration in Pabbly Connect
To finalize the integration, click on “Save and Send Test Request” in Pabbly Connect. This sends the task creation request to ClickUp.
Once the task is created, check your ClickUp account to verify that the task appears with all the lead details filled in. This confirms that the integration is successfully set up.
With this automation, every new lead from Facebook will automatically create a corresponding task in ClickUp, saving you time and effort.
By using Pabbly Connect, you can seamlessly automate the process of creating ClickUp tasks from Facebook leads. This integration saves time and enhances productivity in managing your leads effectively.
