To start automating your WhatsApp messages, you first need to access Pabbly Connect. Open your browser and type in chatflow.pabbly.com to sign up for an account.
Once you log in, you will land on the dashboard where you can connect your WhatsApp number. This is essential for sending automated messages through Pabbly Connect.
2. Setting Up WhatsApp Broadcast in Pabbly Connect
After logging into Pabbly Connect, navigate to the left menu and click on the “Broadcast” button. This will take you to the WhatsApp Broadcast page.
- Click on “Create New Broadcast”.
- Enter a name for your broadcast campaign.
- Select your audience from existing contacts or upload a CSV file.
Once your audience is selected, you can refine it further by excluding specific contacts. This is done in the “Refining Audience” section, which is optional but useful to ensure targeted messaging.
3. Crafting Your Message for Broadcast
In this section, you will select the type of message to send through Pabbly Connect. You can choose between a regular message or a template message. Regular messages require you to write your content, while template messages are pre-approved by WhatsApp.
- Select the message type (Regular or Template).
- For template messages, choose from the approved list.
- Add an image or quick reply buttons as needed.
After crafting your message, you can send a test message to ensure everything looks perfect before broadcasting to your audience through Pabbly Connect.
4. Scheduling Your Broadcast Messages
With your message ready, it’s time to schedule your broadcast using Pabbly Connect. You can choose to send it immediately or select a future date and time.
If you opt for scheduling, simply select the date and time from the calendar. This feature allows you to automate the sending process, ensuring your messages reach customers at the right time.
5. Conclusion: Automate with Pabbly Connect
In conclusion, using Pabbly Connect allows you to automate WhatsApp broadcasts effortlessly. You can send exclusive offers to your customers without manual effort, making the process efficient and effective.
By following the steps outlined, you can easily set up your WhatsApp automation and enhance your customer engagement.
