1. Accessing Pabbly Chatflow for Your WhatsApp Integration
To create an AI-powered WhatsApp assistant, you first need to access Pabbly Chatflow. Start by opening a new tab and navigating to pabbly.com/chatflow. Here, you can either sign in if you are an existing user or click on the “Sign Up Free” button to create a new account.
Upon signing up, you will receive 100 free credits each month. These credits allow you to create and test your assistants. For uninterrupted service, consider upgrading to a premium version of Pabbly Chatflow, which offers thousands of credits monthly.
2. Creating Your WhatsApp AI Assistant in Pabbly Chatflow
Once logged into Pabbly Chatflow, you can create your AI assistant. Click on the “Add Assistant” button to start. Name your assistant something meaningful, like “24×7 Student Support and Query Handling System”.
  • Select the AI agent type for your assistant.
  • Define the role and constraints in the provided box.
  • Set the AI’s creativity level using the temperature setting.
After configuring these settings, click on the “Add Assistant” button to proceed to the next steps of setting up your assistant.
3. Uploading Knowledge Source for Your Assistant
Next, you need to upload a knowledge source that contains all the necessary information your assistant will use. Create a detailed knowledge base in Google Docs, including greetings, FAQs, and specific responses.
To upload this knowledge base, download it from Google Docs in either PDF or TXT format. In Pabbly Chatflow, click on the cloud icon and select “Add New File”. Drag your downloaded file into the upload area and click on the “Upload File” button.
4. Configuring the Assistant Interface in Pabbly Chatflow
After uploading your knowledge source, you can configure the assistant’s interface. In this step, you can customize the display name, initial messages, and privacy policy links.
  • Set your brand name as the display heading.
  • Add initial messages that greet users when they initiate a chat.
  • Include a privacy policy hyperlink for user trust.
Once you have configured these settings, save your changes. This ensures your assistant is ready for user interactions.
5. Testing Your WhatsApp AI Assistant
To ensure your assistant is functioning correctly, you need to test it. Create a WhatsApp chatbot within Pabbly Chatflow and set a trigger keyword, such as “course”. This keyword will activate your assistant.
Once the setup is complete, send the keyword “course” in your WhatsApp chat. The assistant should respond with a welcome message, confirming that it is operational. This interaction demonstrates how Pabbly Chatflow enables seamless communication through the AI assistant.
In this tutorial, we explored how to create a WhatsApp AI assistant using Pabbly Chatflow. By following these steps, you can automate customer support and ensure instant responses to queries, enhancing user experience.
