To start automating customer feedback responses, first access Pabbly Connect by navigating to pabbly.com/connect. This platform is essential for integrating various applications seamlessly.
Once on the homepage, you can either sign in if you are an existing user or click on “Sign Up Free” to create a new account. New users can enjoy 100 free tasks each month, allowing you to explore the features of Pabbly Connect without any cost.
After logging into Pabbly Connect, you will be directed to the workflow page. Here, you can create a new workflow to analyze customer feedback and send automated emails. Start by selecting Google Forms as your trigger application.
- Choose “New Response Received” as the trigger event.
- Click the connect button to generate a webhook URL.
- Copy the webhook URL to link it with Google Forms.
This setup allows Pabbly Connect to automatically fetch responses from Google Forms, streamlining your feedback analysis process.
3. Setting Up Google Forms with Pabbly Connect
Next, head to your Google Forms and navigate to the responses section. Here, you can link your form to Google Sheets, which acts as the data repository.
- Select “View in Sheets” to create a Google Sheet for responses.
- Go to Extensions, then Add-ons, and search for “Pabbly Connect Webhooks”.
- Install the add-on and set up the webhook URL in the initial setup dialog.
By doing this, Pabbly Connect will receive real-time data from Google Forms, enabling you to automate your email responses based on customer feedback.
4. Generating Email Content Using OpenAI
Now that you have set up the Google Forms integration, it’s time to generate personalized email content using OpenAI. In Pabbly Connect, select OpenAI as the action application.
- Choose “Chat GPT” as the action event.
- Connect your OpenAI account by entering your API key.
- Map the feedback details from Google Forms to the prompt for dynamic content generation.
This integration allows Pabbly Connect to utilize AI for crafting tailored email responses based on each customer’s feedback, enhancing engagement and satisfaction.
5. Sending Emails via Gmail
Finally, to send the generated email content, select Gmail as the action application in Pabbly Connect. This step finalizes the automation process.
- Choose “Send Email” as the action event.
- Connect your Gmail account, either by signing in or using an existing connection.
- Map the recipient’s email address and the generated content to the email fields.
By completing these steps, Pabbly Connect ensures that your customers receive timely and relevant responses, keeping them engaged with your business.
In this tutorial, we explored how to automate customer feedback responses using Pabbly Connect, integrating Google Forms and OpenAI for efficient email communication. This automation enhances customer engagement and streamlines your business processes.
