1. Setting Up Pabbly Connect for WhatsApp AI Integration
To create a WhatsApp AI chatbot, you first need to set up Pabbly Connect. This platform enables seamless integration between your WhatsApp and AI functionalities. Start by visiting the Pabbly Connect website and signing up for an account.
Once signed in, navigate to the Pabbly Connect dashboard. Here, you will find options to connect various applications, including WhatsApp. This is where the integration magic happens, allowing you to automate responses to customer queries.
2. Accessing Pabbly Chartflow to Create Your AI Assistant
Next, access the Pabbly Chartflow application from your dashboard. This tool is essential for building the AI assistant that will interact with your customers on WhatsApp. Click on the “Access Now” button to enter the Chartflow interface.
  • Sign in or sign up for a new account.
  • Navigate to the Pabbly Chartflow dashboard.
  • Click on “Add WhatsApp Number” to link your business WhatsApp.
After adding your WhatsApp number, you can start building your AI assistant. This will allow you to automate responses effectively, ensuring your customers receive timely information.
3. Creating Your WhatsApp AI Assistant with Pabbly Connect
Now it’s time to create your AI assistant using Pabbly Connect. Click on the “Add” button to start a new assistant flow. You will need to give your assistant a name and select the type of instruction from the dropdown menu.
Choose between a custom prompt or predefined options like “AI agent” or “customer support agent”. For this tutorial, we will select the AI agent option, which will automatically populate some basic instructions. You can customize these as needed.
4. Configuring AI Settings for Optimal Performance
Configuring the AI settings is crucial for ensuring that your assistant provides accurate responses. In this section, you will set the temperature for responses, choose the AI model, and enter your OpenAI API key. This is where Pabbly Connect facilitates the connection to AI capabilities.
Here are the steps to configure your AI assistant settings:
  • Set the temperature for response creativity (0 for focused, 1 for creative).
  • Select the AI model from the dropdown (e.g., GPT 5.2).
  • Input your OpenAI API key to enable AI functionalities.
Once these settings are configured, your AI assistant will be ready to handle customer inquiries effectively.
5. Activating and Assigning Your AI Assistant
After setting up your AI assistant, the final step is to activate it. This is done by enabling the assistant and saving your settings in Pabbly Connect. Make sure to assign it to your WhatsApp chats for it to function correctly.
You can assign the assistant to multiple contacts or individual chats. To do this, navigate to the inbox settings and select the AI auto-reply settings. Here, you can choose the contact list and assign the assistant accordingly.
Once assigned, your assistant will automatically respond to customer queries on WhatsApp, providing a seamless experience for both you and your customers.
In this tutorial, we explored how to create a WhatsApp AI chatbot using Pabbly Connect. By following these steps, you can automate customer interactions effortlessly, ensuring timely responses and improved customer satisfaction.
