1. Accessing Pabbly Chatflow for Integration
To create an admission and student inquiry bot, start by accessing Pabbly Chatflow. Open your browser and navigate to the Pabbly Chatflow website at www.pabbly.com/chatflow. You will need to sign in to your account.
If you’re a new user, click on the “Sign Up for Free” option to receive 100 free credits monthly. Existing users can simply sign in. Once logged in, you will see the dashboard of Pabbly Chatflow, which allows you to manage your integrations and settings.
2. Connecting WhatsApp to Pabbly Chatflow
After accessing Pabbly Chatflow, connect your WhatsApp number. Click on the “WhatsApp Connect” option, which is the preferred method for integration. You can also opt for a manual token method if necessary.
- Choose the “WhatsApp Connect” method.
- Follow the prompts to link your WhatsApp account.
- If using the manual token, ensure you have your token ready.
Once your WhatsApp is connected, you can start creating your AI assistant within Pabbly Chatflow to handle student inquiries effectively.
3. Creating Your AI Assistant in Pabbly Chatflow
To create an AI assistant, navigate to the “AI Assistant” section within Pabbly Chatflow. Click on “Create New Assistant” and name it, for example, “Admission and Student Inquiry Bot”. This assistant will automate responses to student queries.
Next, configure the AI settings by selecting the instruction type as “AI Agent”. You can enhance the instructions based on the specific needs of your college. The AI will utilize OpenAI’s GPT-5 mini model, so ensure you have an API key from OpenAI to proceed.
- Set the temperature for creative responses (0 for focused, 1 for creative).
- Input your OpenAI API key to connect the AI model.
- Adjust the settings for retry attempts and fallback messages.
After configuring these settings, save your AI assistant to enable it for use in Pabbly Chatflow.
4. Uploading Knowledge Base for AI Responses
For your AI assistant to provide accurate answers, upload a detailed knowledge base file. This file should contain all relevant information about your college, including courses, admission processes, and contact details.
In Pabbly Chatflow, go to the “Knowledge Source” section and click on “Upload File”. Select the file you prepared and ensure it contains comprehensive details for the AI to reference.
- Ensure the file is in PDF format and does not exceed 10 pages if it contains images.
- Include all essential details such as course offerings and application processes.
- Save the knowledge base to enhance the AI’s response capability.
Once uploaded, your AI assistant in Pabbly Chatflow will be equipped to answer queries based on the information provided in the knowledge base.
5. Assigning the AI Assistant to Contacts
To effectively utilize your AI assistant, assign it to specific contacts or groups. In Pabbly Chatflow, navigate to the “Inbox Settings” and enable the AI auto-reply feature. This will allow the assistant to respond to incoming messages automatically.
Select the list of contacts you want to assign the assistant to. You can add rules to assign the AI assistant to all contacts or specific groups based on your needs.
- Choose the AI assistant you created for the assignment.
- Save the rules to activate the assistant for those contacts.
- Test the setup by sending a message to ensure the AI responds correctly.
By assigning your AI assistant in Pabbly Chatflow, you ensure that students receive timely and accurate responses to their inquiries.
In conclusion, using Pabbly Chatflow allows you to create an efficient admission and student inquiry bot that automates responses via WhatsApp. By following the steps outlined, you can enhance your college’s communication and support services.
