To start automating your content creation, first access Pabbly Connect. Visit Pabbly.com and either sign in if you’re an existing user or click on “Sign Up Free” to create a new account. Once logged in, navigate to the “Pabbly Connect” dashboard.
Here, you can create a new workflow. Click on “Create New Workflow” and name it something like “AI Se Social Media Content Automatically Banayein”. Select an appropriate folder for your workflow. This sets the stage for integrating Google Sheets, Facebook, and OpenAI seamlessly through Pabbly Connect.
2. Setting Up Google Sheets Integration
In this section, we will set up Google Sheets as the trigger for our workflow. Using Pabbly Connect, select Google Sheets and choose the event “New or Updated Spreadsheet Row”. Click on “Connect” to establish a connection.
  • Select “New or Updated Spreadsheet Row” as your trigger event.
  • Click “Connect” to generate a webhook URL.
  • Copy the generated webhook URL for the next steps.
Now, go to your Google Sheets, click on “Extensions”, then “Add-ons”, and select “Get Add-ons”. Search for “Pabbly Connect Webhook” and install it. Refresh your Google Sheets to ensure the add-on is active. Next, click on “Initial Setup” in the Pabbly Connect add-on and paste the webhook URL you copied earlier. Specify the trigger column (for example, column E) and click “Send Test” to verify the connection.
3. Generating Content with OpenAI
After successfully setting up Google Sheets, the next step is to generate content using OpenAI. In Pabbly Connect, add a new action step and select OpenAI. Choose the event “ChatGPT” and click on “Connect”.
If you’re creating a new connection, you will need to enter your OpenAI API key. You can generate this key from the OpenAI dashboard. Once connected, select the GPT model you wish to use, such as GPT-4, and input your prompt. This prompt should instruct OpenAI to generate engaging content based on the data received from Google Sheets.
  • Select the appropriate OpenAI model (e.g., GPT-4).
  • Map the fields from Google Sheets to your prompt for content generation.
  • Click “Save and Send Test Request” to generate the content.
Once the content is generated, you will receive a response that includes the content to be posted on Facebook. This step effectively automates the content generation process using Pabbly Connect.
4. Posting Content to Facebook
The final step in this automation process is to post the generated content to Facebook. In Pabbly Connect, add another action step and select Facebook. Choose the event “Create Page Post” and click on “Connect”.
You will need to link your Facebook account to Pabbly Connect. Once connected, select the Facebook page where you want to post the content. Map the generated content from the OpenAI step to the message field in the Facebook post. You can leave the link URL field empty if you don’t have any links to share.
  • Select the Facebook page for posting.
  • Map the generated content to the message field.
  • Click “Save and Send Request” to post the content.
After successfully posting, check your Facebook page to confirm that the content appears as intended. This step completes the automation process using Pabbly Connect.
5. Conclusion
In this tutorial, we explored how to automate social media content creation using Pabbly Connect by integrating Google Sheets, OpenAI, and Facebook. By following these steps, you can efficiently create and post content without manual intervention.
Utilizing Pabbly Connect streamlines your workflow, allowing you to focus on other important aspects of your business. Automate your content creation today and enhance your social media presence effortlessly.
