1. Access Pabbly Connect to Start Integration
To begin the integration process using Pabbly Connect, log in to your Pabbly account. Once logged in, navigate to the “Access Now” button for Pabbly Connect.
After clicking the button, you will be directed to the Pabbly Connect dashboard. From here, you can create a new workflow that will automate the blog generation process.
2. Set Up Google Sheets as the Trigger App in Pabbly Connect
In this step, you will set Google Sheets as the trigger app using Pabbly Connect. Click on “Add Trigger” and choose Google Sheets as your application.
Next, select the event “New and Updated Spreadsheet Row”. This event will trigger the workflow whenever a new topic is added to your Google Sheets. Follow these steps:
  • Click on “Connect” to establish a connection.
  • Copy the webhook URL provided.
  • Go to Google Sheets and install the Pabbly Connect WBooks add-on.
Once the add-on is installed, refresh Google Sheets and set up the initial configuration by entering the copied webhook URL. This setup will allow data to flow from Google Sheets to Pabbly Connect.
3. Configure Pabbly Connect WBooks for Google Sheets
Now that you have connected Google Sheets, it’s time to configure Pabbly Connect WBooks. In your Google Sheets, navigate to the Pabbly Connect WBooks add-on.
Click on “Initial Setup” and enter the webhook URL you copied earlier. Additionally, specify the trigger column, which is the last column of your data. This configuration ensures that whenever you enter data in the trigger column, it will send the complete row to Pabbly Connect.
4. Generate Blog Content Using OpenAI
With your Google Sheets set up, the next step is to generate blog content using OpenAI via Pabbly Connect. Click on “Add Action” and select OpenAI as your application.
Choose the event “Chat GPT” and connect it to your OpenAI account. You will need to enter your API token, which can be obtained by creating a new secret key in the OpenAI dashboard. After setting up the connection, you’ll specify the prompt for generating content.
  • Enter the details received from Google Sheets such as topic, keywords, and target audience.
  • Map these fields correctly to ensure dynamic response generation.
After mapping, save and test the action to check if the content is generated correctly. This will allow you to create engaging blog posts automatically.
5. Post Generated Content to WordPress
The final step is to post the generated content to your WordPress site using Pabbly Connect. Click on “Add Action” again and select WordPress as your application.
Choose the event “Create a Post” and connect it to your WordPress site. Enter your WordPress credentials and specify the base URL. Ensure to map the post title and content fields correctly from the OpenAI response.
  • Set the post status to “Publish” to make it live immediately.
  • Check the response to confirm that the post was created successfully.
With this setup, every time you add a new topic to Google Sheets, a blog post will be automatically generated and published on your WordPress site, facilitated entirely by Pabbly Connect.
This tutorial demonstrated how to automate blog generation using Pabbly Connect, Google Sheets, OpenAI, and WordPress. By following these steps, you can streamline your content creation process effectively.
