To start automating your LinkedIn posts, first, access Pabbly Connect. If you’re a new user, open a new tab and search for pabbli.com/connect in your browser.
Once on the landing page, click on the “Sign Up for Free” option located in the top right corner. You can utilize 100 tasks free each month to explore Pabbly Connect and experience its capabilities for posting on LinkedIn.
After signing in, navigate to the workflow builder within Pabbly Connect. This is where you will create your automation. Click on the “Add Trigger” button to start the process.
  • Select “Schedule by Pabbly” as the trigger application.
  • Choose “Schedule Workflow” for the event.
  • Set the frequency to run the workflow daily.
Now, specify the time you want the workflow to run, such as 2 PM daily, and click the “Save” button. Your automation is now scheduled to execute every day at the designated time.
3. Integrating OpenAI with Pabbly Connect
Next, you will integrate OpenAI to generate content for your LinkedIn posts. Click on the “Add New Action Step” and search for OpenAI, selecting it as your action application.
For the event, choose “GPT” and click on “Connect”. If you already have a connection set up, select it. If not, you will need to create a new connection by providing your OpenAI API key.
  • Log into your OpenAI account to retrieve your API key.
  • Navigate to the API key section and create a new secret key.
  • Copy the generated key and paste it into your Pabbly Connect workflow.
After saving the connection, select the AI model you wish to use, typically GPT-5, and enter your prompt for content generation. Once your prompt is ready, click on the “Save and Send Test Request” button to generate the LinkedIn post.
4. Posting Generated Content to LinkedIn
Now that you have generated content, it’s time to post it on LinkedIn. Click on “Add New Action Step” and search for LinkedIn, selecting it as your action application.
Choose the event as “Share a Simple Text” and click on “Connect”. If you have an existing connection, select it; otherwise, create a new connection by logging into your LinkedIn account.
  • Ensure your LinkedIn account is logged in to allow Pabbly Connect access.
  • Select the author and map the content generated from OpenAI.
  • Set the visibility to public and save your settings.
After saving, click on the “Save and Send Test Request” button to post the content on your LinkedIn account. Refresh your LinkedIn page to see the new post live.
5. Conclusion: Automate Your LinkedIn Posts with Pabbly Connect
By following these steps, you can successfully automate your LinkedIn posts using Pabbly Connect and OpenAI. This integration allows you to generate and post content effortlessly every day.
Utilizing Pabbly Connect streamlines your social media management, ensuring consistent engagement with your audience while saving you time. Start automating your posts today to enhance your online presence!
