To start creating a WhatsApp chatbot, you first need to access Pabbly Connect. Open your browser and go to www.pabbly.com/chartflow. This is where you will create your WhatsApp AI agent.
Once on the Pabbly Chartflow page, sign in with your existing account or sign up for a free trial. This will allow you to explore the features available, and you can use the credits provided to test the service before committing.
2. Setting Up Your WhatsApp Number in Pabbly Connect
After signing into Pabbly Connect, navigate to the app dashboard. Here, you can add your WhatsApp number, which is essential for your chatbot to function. Click on the ‘Add WhatsApp Number’ button to begin the setup process.
- Select the preferred method to connect your WhatsApp.
- You can either use WhatsApp connect or a manual token.
- Follow the prompts to complete the connection.
Once your WhatsApp number is added, you can move on to creating your AI assistant for the chatbot. This will allow you to automate responses to customer inquiries effectively.
3. Creating the AI Assistant in Pabbly Connect
To create your AI assistant, select the ‘AI Assistant’ option from the left-hand menu in Pabbly Connect. Click on ‘Add Assistant’ and name your assistant, such as “AI Chatbot for Dentist”.
In the assistant configuration, you’ll need to set the instructions and parameters for the AI. Choose ‘AI agent’ as the instruction type and adjust the temperature setting to control the creativity of the responses. A setting of 0.8 is recommended for balanced creativity.
- Enter your OpenAI API key to establish a connection.
- Set up fallback messages for when the AI cannot answer a query.
- Configure retry attempts for unresolved questions.
With these settings, your AI assistant will be ready to respond to customer inquiries effectively, enhancing your customer service capabilities.
4. Uploading Knowledge Base for Your Chatbot
The next step in using Pabbly Connect involves uploading a knowledge base for your AI assistant. This knowledge base should contain essential information about your business, such as services offered and FAQs.
To upload the knowledge base, click on the ‘Upload File’ option and select your document. Make sure it includes all relevant details, such as working hours, pricing, and appointment booking procedures.
Once uploaded, the AI assistant will reference this knowledge base when responding to customer questions, ensuring accurate and helpful replies. This step is crucial for maintaining high-quality customer interactions.
5. Assigning the AI Assistant to Contacts in Pabbly Connect
After setting up your AI assistant in Pabbly Connect, you can assign it to specific contacts or groups. Navigate to the inbox settings and enable the AI auto-reply feature.
- Select the AI assistant you created for assignment.
- You can choose to assign it to all contacts or specific lists.
- Save the settings to activate the AI assistant.
This feature allows your chatbot to respond automatically to inquiries, streamlining communication and improving customer satisfaction.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Connect. By following these steps, you can effectively automate customer interactions and enhance your business operations.
