To start using Pabbly Chatflow, navigate to the official website and create an account. This platform is crucial for integrating WhatsApp with your business processes.
Once you sign up, you will receive 100 free credits each month, allowing you to create AI assistants without any cost. This feature enables you to automate responses for patient inquiries effectively.
2. Creating an AI Assistant in Pabbly Chatflow
After logging into Pabbly Chatflow, click on the “Add Assistant” button. This step is essential for setting up your AI assistant that will handle patient queries.
- Select a meaningful name for your assistant.
- Define the AI instructions based on your business needs.
- Configure settings like temperature and API keys for OpenAI.
By following these steps, you will create an AI assistant tailored to your clinic’s needs, allowing for efficient patient management.
3. Setting Up WhatsApp Integration with Pabbly Chatflow
To enable WhatsApp integration, add your WhatsApp number in Pabbly Chatflow. This step is critical for your assistant to interact with patients through WhatsApp.
After adding your number, create a flow that triggers the assistant when patients send specific keywords like “appointment.” This ensures that the AI assistant responds promptly to inquiries.
- Go to the flow builder and select the trigger event for keywords.
- Assign the AI assistant to respond to the triggered keywords.
- Save the flow to ensure it functions correctly.
This setup allows your AI assistant to handle patient requests seamlessly, enhancing the overall patient experience.
4. Integrating Knowledge Base with Pabbly Chatflow
To improve the AI assistant’s responses, upload a knowledge base containing all crucial information about your clinic in Pabbly Chatflow. This knowledge base should be in PDF or TXT format.
Once uploaded, the assistant will use this information to answer patient queries accurately, ensuring that all interactions are informative and helpful.
- Prepare your knowledge base with detailed information about services offered.
- Upload the file to Pabbly Chatflow and link it to your assistant.
- Ensure the assistant can access this knowledge base for accurate responses.
With a well-structured knowledge base, your AI assistant will provide timely and relevant answers to patient inquiries, improving service quality.
5. Testing Your AI Assistant in Pabbly Chatflow
After creating your AI assistant and integrating it with WhatsApp, it’s essential to test its functionality. Use the keyword “appointment” in a WhatsApp message to trigger the assistant.
This testing phase will confirm that your assistant responds correctly and efficiently to patient requests. Ensure that the welcome message and appointment booking functionalities work as intended.
- Send the keyword to your WhatsApp number to trigger the assistant.
- Check for the welcome message and follow-up prompts.
- Make adjustments if necessary based on the test results.
By thoroughly testing your AI assistant in Pabbly Chatflow, you can ensure a smooth and efficient experience for your patients, significantly enhancing your clinic’s operational efficiency.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Chatflow to automate patient management effectively. By following these steps, you can create a seamless experience for your patients, reducing manual effort and improving service quality.
