To begin automating blog creation, first access Pabbly Connect by visiting pabby.com in your browser. If you are a new user, sign up for free to get 100 tasks monthly, which allows you to test the platform’s capabilities.
Once logged in, navigate to the Pabbly Connect dashboard where you can create new workflows. Click on the “Create from Scratch” option to initiate your automation process. This is where you will set up the integration between Google Sheets and WordPress using Pabbly Connect.
Now that you are in the Pabbly Connect dashboard, it’s time to create a workflow. Name your workflow appropriately, such as “AI Blog Automation for Real Estate Websites.” This will help you identify it later. Select the appropriate folder for organization.
  • Click on the “Create” button to finalize your workflow setup.
  • Choose Google Sheets as your trigger application.
  • Select “New or Updated Spreadsheet Row” as the trigger event.
After selecting your trigger, connect Pabbly Connect to Google Sheets by following the prompts to generate a webhook URL. This URL will allow Google Sheets to send data to Pabbly Connect whenever a new row is added.
3. Setting Up Google Sheets with Pabbly Connect
With your workflow created, open Google Sheets to set up your spreadsheet, which should contain all relevant fields for your blog posts, such as Topic, Location, and CTA. Install the Pabbly Connect Webhooks add-on if you haven’t already.
  • Go to Extensions > Add-ons > Get Add-ons.
  • Search for Pabbly Connect Webhooks and install it.
  • Refresh your Google Sheets to see the new add-on.
After refreshing, navigate to Extensions > Pabbly Connect Webhooks > Initial Setup to enter the webhook URL generated in Pabbly Connect and specify the trigger column. This setup ensures that every time a new blog idea is added in the specified column, it triggers the workflow in Pabbly Connect.
4. Integrating OpenAI for Blog Generation
Next, you will integrate OpenAI to generate blog content based on the data from Google Sheets. In your Pabbly Connect workflow, select OpenAI as the action application and choose “ChatGPT” as the action event.
  • Connect to OpenAI by entering your API key.
  • Select the model you wish to use, such as GPT-4 or another variant.
  • Enter a prompt that instructs OpenAI to generate a blog based on the data received.
Make sure to map the fields from Google Sheets to your prompt. This allows OpenAI to dynamically generate content based on the latest entries, ensuring your blog posts are always relevant and up-to-date.
5. Posting Generated Blogs to WordPress
Finally, set up the integration with WordPress to publish the generated blog posts. In your Pabbly Connect workflow, select WordPress as the action application and choose “Create a Post” as the action event.
  • Connect to your WordPress account by entering your base URL and credentials.
  • Map the title and content fields from the OpenAI response to the WordPress post fields.
  • Set the post status to “Published” for immediate posting.
After completing the mapping, save and send the test request to ensure everything works correctly. If successful, you will see your new blog post appear in WordPress, confirming that Pabbly Connect has effectively automated your blogging process.
In this tutorial, we explored how to automate blog creation using Pabbly Connect with Google Sheets and WordPress. By following these steps, you can streamline your content creation process and enhance your blogging efficiency.
