To start using Pabbly Connect, open a new tab and search for pabby.com/connect. This will take you to the Pabbly Connect landing page where you can sign up for a free trial.
Click on the “Sign Up for Free” button to create your account. After signing up, log in to access the Pabbly Connect dashboard. From here, you can create a workflow that integrates various applications with Pabbly Connect.
Once logged into Pabbly Connect, navigate to the “Create Workflow” section. You can choose to create from scratch or use AI features. For this tutorial, select “Create from Scratch” and name your workflow, for example, “AI Automation”.
- Click on the “Create” button after selecting your folder.
- A blank workflow builder will appear where you can add triggers and actions.
In this workflow, you will first add a trigger. The workflow operates on two principles: trigger and action. The trigger starts the workflow, and the action responds to that trigger. Choose an application for your trigger, like “Schedule” to run your workflow daily at 12:00 PM.
3. Adding AI Steps to Pabbly Connect
After scheduling your trigger in Pabbly Connect, you can add an AI step. Click on the “Add New Action Step” button and search for “OpenAI”. Select it and choose the event as “Chat GPT”.
To connect Chat GPT with Pabbly Connect, you will need an API token. Click on “Add a New Connection”. You will be prompted for a token, which you can obtain from the OpenAI API page. Create a new secret key and paste it into the required field in Pabbly Connect.
- Go to the OpenAI API page and create a new secret key.
- Paste the key into Pabbly Connect and save it.
Once connected, select your AI model and input your prompt. For example, if you want to generate a blog title, write a clear prompt and submit it. This will allow Chat GPT to generate a title based on your requirements.
4. Integrating More Applications with Pabbly Connect
Besides OpenAI, you can integrate other tools like Gemini using Pabbly Connect. To do this, add another action step and search for “Gemini”. Select the event to generate content.
As with OpenAI, you will need to create an API key from Google AI Studio. Navigate to the API key section and create a new key. This key will also need to be pasted into Pabbly Connect to establish the connection.
- Create a new API key in Google AI Studio.
- Paste the key into Pabbly Connect to connect Gemini.
Once connected, you can input your prompt and select the method to generate content. This flexibility allows you to automate various tasks seamlessly with Pabbly Connect.
5. Automating Content Generation with Pabbly Connect
Using Pabbly Connect, you can automate content generation for platforms like Google Blogger and social media. For instance, you can set a workflow to generate a blog title and content every day at a specific time, which will then be automatically posted to Google Blogger.
Additionally, you can create workflows that generate images based on content and post them on your Facebook page. This is done by mapping details from Google Sheets to generate images and then posting them directly.
- Schedule daily content generation for blogs.
- Automatically post generated content to your Facebook page.
This feature enables you to create multiple AI automations, enhancing your business operations and efficiency.
In this tutorial, we explored how to use Pabbly Connect to integrate various applications like Pabbly, GPT, Lindin, Google, Facebook, and YouTube. By following the steps outlined, you can automate your business processes efficiently.
